In August of 2010, we moved from Vantage using Progress to Epicor using Progress. It still took two days to do the conversion.
Regards,
Dale
Regards,
Dale
--- In vantage@yahoogroups.com, "Brian Roberts" <broberts@...> wrote:
> We are in the middle of converting from Vantage 6.1 (on Progress) to
> Epicor 9.05 on MS SQL. We looked briefly at going to 9.05 on Progress,
> but went MS SQL because of in-house SQL knowledge (& lack of Progress
> knowledge), reporting, and other planned development that will be using
> SQL. We didn't look seriously at the Progress-with-replication-to-SQL
> option, but after seeing all the Progress app servers, schema holder
> database, admin tools etc still required, I think we should have
> investigated it more.
> One detail not mentioned below: if you have a Progress database now,
> getting that converted to MS SQL takes money (to Epicor) and time (a
> couple days for our database). I have no idea how this compares to the
> cost & install time for the replication option, but that 2 day
> conversion time is a headache for us.
> Brian.
> Of pbparker
> Sent: Tuesday, January 18, 2011 9:57 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: SQL vs. Progress for Epicor 9
> I've contemplated converting over to SQL but I can never get a cost from
> Epicor on how much it's going to cost to convert. They say it all
> depends - but are never specific so I have no ballpark figure even on
> what the cost is going to be. Kind of unreal.
> --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , Toby
> Boogerd <tboogerd@> wrote:
> > Just wanted to follow-up and see what options you chose and how that
> all worked out for you. We are currently on 6.1 Progress and I would
> like to get to E9 on progress with replication to SQL. Anyone having
> done this or in the process I would love to hear how you did it, the
> process, and the experience (good or bad) and how things are today.
> > From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On
> Behalf Of saab_barracuda
> > Sent: Thursday, September 17, 2009 9:33 AM
> > To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> > Thanks Pim! This sounds like the best option I've heard. Best of both
> worlds like you said. It seems we are looking at midyear 2010 at the
> earliest for the upgrade so we have some time to investigate these new
> options with E9. MUCH APPRECIATED!!!
> <mailto:vantage%40yahoogroups.com>, Pim Zandbergen <P.Zandbergen@>
> wrote:
> > > Vic Drecchio wrote:
> > > > My logic is converse to your question. I ask: What reason would I
> have
> > > > to go with Vantage on a Progress database?
> > > Because, at the heart, Vantage 8/Epicor 9 is a Progress application.
> > > Epicor marketing seems to be hiding this fact alltogether.
> > > They only talk about Epicor using Microsoft Technlogy.
> > > Sure, it is not untrue; the client is written in .Net (using
> Progress
> > > Open Client technology) and the backend can be a third party
> database,
> > > using ODBC, SQL Server in this case. But the core technology is
> Progress.
> > > That means the Progress database is native to the application.
> > > Progress Appservers use shared memory to access the Progress
> database.
> > > If you want to replace the Progress database with SQL Server, you
> are
> > > actually replacing the Progress database with a Progress dataserver,
> > > a process that translates Progress 4GL data requests to ODBC.
> > > Go figure how efficient that could ever be. It also means you still
> > > need to know about Progress to keep things running. In fact you
> > > need to know even more, because you need to install more Progress
> > > software modules than native Progress database users have to.
> > > Of course, you could spend more on hardware in order to compensate
> for
> > > the inefficiency. But spending that extra money on even better
> hardware
> > > for Progress will be more rewarding. You need all the performance
> you
> > > can get to keep your users satisfied.
> > > Having said that, it should also be said that Epicor 9 allows you to
> > > benefit from the best of both worlds. Epicor 9 now allows your
> Progress
> > > database to be replicated to an external SQL Server database,
> allowing
> > > you to do all your reporting, data mining and business intelligence
> > > from that secondary database.
> > > This is really ideal. Your Progress database is only used to
> efficiently
> > > serve your core application, and reporting is done on a platform
> that
> > > excels in that area.
> > > Having this secondary server running SQL Server is a good idea for
> other
> > > stuff too. It's the best place for Service Connect, for Portal, for
> > > Information Worker, for PLM, for APM and lots of other modules that
> > > require SQL Server for their private storage.
> > > Epicor 9 Enterprise Search (which is really cool) _requires_ this
> kind of
> > > setup if you use a Progress database.
> > > Pim
