Hello,
Newbie SQL DB Admin here…and I’m trying to schedule backups and maintenance jobs (specifically index rebuild) against our ERP10 database to get it ready for when we go Live…uh, eventually. Just wondering has anyone implemented this SQL Server Maintenance Solution from Ola Hallengren?
I thought it looked like a good option to achieve all of this. How is it working for you and would you be able to answer a few (hopefully simple) questions that I have about it?
We are currently running ERP10.1 on SQL 2012 Standard -
I read that in SQL Standard the rebuild index process will be OFFLINE which locks tables and can cause blocking issues. So it would be best to schedule the rebuild process for a time when no one is using the database…which as of now we could get away with doing…
But that SQL Enterprise could run the rebuild process ONLINE which almost sounds like reason enough to go to Enterprise.
Just wondering, there are probably a lot of glaring obvious ones that I just haven’t read about yet, but what would be other major benefits of going with the Enterprise? (Besides exploring strange new worlds, new life, and new civilizations and boldly going where no one has gone before…LOL ) And what are those benefits that you have actually implemented and used for your Epicor databases?
And what about the age old question of upgrading from 2012 to 2014 or the latest version of 2016 (is 2016 approved yet for use with Epicor?)? Because if we move from 2012 Standard to Enterprise anyways, should we just go all the way and upgrade to 2014 or 2016 Enterprise?
Thanks for any thoughts, suggestions, help or advice.
