Specifying criteria for specific Job Numbers
I’m sure this is an easy question for most of you; however I am having difficulty specifying this in my BAQ.
I have a BAQ where I want to pull Job Numbers EXCEPT for Job Numbers that contain:
-R
-E
etc.
How and where do you specify NOT to choose something or to ignore fields that contain specific information?
Please note that I do not write any SQL code, I use the ‘Business Activity Query Designer’.
In advance thank you for your time (and patience).
Judy
Check the ‘Not’ box and use the LIKE Operation on the JobNum field. Your constant should be %-N% (% being the wild card)
I was so close!
Thank you so much for your help!
Back to my BAQ’s…:slightly_smiling_face:
