I’ve read through some other similar posts and I’m not finding this situation. I think I found a menu that is bugged and won’t accept any customization in Menu Maintenance. It’s PCID Build/Split/Merge. I’m on 10.2.300 and I’ve tested on 10.2.500 as well and neither allow me to specify a customization.
How do I work around? I tried a UBAQ but it did not allow me to save unfortunately.
I have tried as All Companies and also as company specific.
I had the same issue with the Supplier Tracker. I created an updated BAQ on the Ice.Menu table. The arguments field should have -formName followed by the form name and then -c followed by the customization name. For example, on my supplier form I have this:
The customization name is SuppChanges and the form is the SupplierTrackerForm
Attaching the UBAQ I use in case looking at it helps. tedUBAQMenu.baq (25.9 KB)
I’m sorry, after looking at little more on some forms you won’t need the form name, just the -c and customization name.
I did see you mentioned using a BAQ but hopefully something in mine (which did work for my situation) will help lead you the right direction for yours.
