Thank you all for the feedback and advice!
Ree
Group:
We are working on uploading our company’s data into Epicor 9.05.604 (we are currently using eBackOffice 7.2.03 sp5, so the process is an adventure all on its own) and have run into a snarl.
Engineering maintains a very extensive part description on some parts. Here is an example:
#18 BLK #8522 X 5IN (W18-30) C/O & STRIP .25 EA END, **(USE 8509708)** BARREL LOCK (F) TYPE W/ WEATHER SEAL - AS PURCHASED (TG #2500094-AS)
We are being advised that all special characters need to be stripped out of our part descriptions – that they can cause issues in E9. Why would special characters cause issues in E9 in what is, essentially, a text field? Is this true of all special (non-alpha-numeric, plus dash and underscore) characters?
We are also being advised that we need to change some of our part numbers to replace backslash characters with underscores. Is there any workaround for this?
Thanks!
Ree
Ree
Group:
Thanks!
Ree
