Great suggestion. That worked. But I'd still like to know how to do this on the client side.
-bws
Brian W. Spolarich ~ Manager, Information Services ~ Advanced Photonix / Picometrix
    bspolarich@... ~ 734-864-5618 ~ www.advancedphotonix.com
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Tony Hughes
Sent: Tuesday, April 27, 2010 4:00 PM
Subject: [SPAM] Re: [Vantage] Disabling a Field Based on User Group Membership
Importance: Low
How about using BPM for RMADisp.Update to see if Date04 changed, and if so, raise error unless you are in security group XYZ?
Sent: Tue, April 27, 2010 2:46:47 PM
Subject: RE: [Vantage] Disabling a Field Based on User Group Membership
Thanks Tony, but if I recall correctly, Vantage field-level security doesn't let me set the field (RMAHead.Date04) to be read-only vs. read-write. I don't want to hide the field from folks, just make it so that only authorized users can change it.
Basically I'm trying to setup an approval process. We don't want to use Vantage's built-in RMA disposition process because of accounting issues (it puts customer-owned parts on our books which we don't want), so we're rolling our own.
So what I'm looking to do is have field on a custom tab on the RMA form pointing at RMAHead.Date04 that only users in the "GM" group can modify, and everyone else can view.
-brian
bspolarich@advanced photonix. com ~ 734-864-5618 ~ www.advancedphotoni x.com
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf Of Tony Hughes
Sent: Tuesday, April 27, 2010 3:33 PM
To: vantage@yahoogroups .com
Subject: Re: [Vantage] Disabling a Field Based on User Group Membership
Brian,
Not 100% clear from what you're wanting to do, but if the field ties right in to a table field there's a very easy way:
Go to Field Security in Security maintenance, open the table, select the field, and click 'New'.
Now you can set permissions to a particular group.
Also, if you want to remove the setting, it feels wrong, but highlight the field on left side and Delete it. All you're doing is deleting that there's security on it, putting it back to Everyone can see it.
____________ _________ _________ __
From: Brian W. Spolarich <bspolarich@advanced photonix. com>
Sent: Tue, April 27, 2010 2:10:13 PM
Subject: [Vantage] Disabling a Field Based on User Group Membership
I want to disable a field on a customization on a form (on a new tab,
if that matters) unless the user is a member of a particular Vantage
security group.
I'm assuming that what I should do is set the field's Enabled property
to false, and then add some code to the form's OnLoad event to set the
Enabled property of the control to true if the user is in the "GM" group
in this case.
Does anyone have a detailed enough example that I can hack into
usability?
-bws
Picometrix
<mailto:bspolarich@ advanced photonix. com> ~ 734-864-5618 ~
www.advancedphotoni x.com <http://www.advanced photonix. com>
(1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto: http://groups. yahoo.com/ group/vantage/ files/.
(2) To search through old msg's goto: http://groups. yahoo.com/ group/vantage/ messages
(3) To view links to Vendors that provide Vantage services goto: http://groups. yahoo.com/ group/vantage/ linksYahoo! Groups Links
-bws
Importance: Low
-brian
Brian,
security group.
in this case.
usability?
-bws
Picometrix
