Not sure when or how, but Pilot has been deleted from our app server. Could have been me, probably was me. How do I get that back on there so I can install Pilot on other machines?
It may just be re-registering it. Look at how much deleted it is first. Do you still have the database listed in the DB Server list? If so in Server Mgt try Register Existing Application Server. If it is not in the list remaking Pilot is not a big task.
I am still able to access Pilot. I copied the test shortcut and just changed the path to pilot. So I still have it in the system, I just can’t figure out where the install file is.
Do test and pilot share a server. If so they both install from the same deployment share.
They do share the same server, but when I tried to install on another PC, it didn’t install Pilot. Just everything else. I got it working for now, but just seems strange.
You should get a list of all of the app servers on that server. You can comingle them in one install or install them in different runs in different folders…
