In Solution Workbench, there is no Base Element for Predictive Searches. However, in the Solution Element Search form, you can select the User Defined tab and then select Get Adapters. Then select the PredictiveSearchAdapter that runs that Search and select the Predictive Search needed. However, this results in the following error using E10.1.400.16:
PROBLEM DESCRIPTION: When a Predictive Search (adapter) is added to a Solution, the Solution Workbench Build process displays the following Build Error:
Unable to retrieve the row from Ice:BO:QuickSearch with SysRowID ‘628fa1a0-82df-430f-8c2b-0320e945d202’. Record Not Found Error
Epicor Support recommended as a workaround: Export the BAQ from the Build System and then Import the BAQ into the Install System. Then create the Predictive Search in the Install System.
Does anyone know of a workaround for the aforementioned problem?
