Site switch to turn off AMM request move by transaction type
(Brad Boes) #1
Would like a central place on the site configuration AMM tab to default the Request Move checkboxes either on or off for each of the material movement types.
(Jose C Gomez) #2
Agree+++++ The all or nothing approach to MRQ is suuuper annoying
(Joshua Giese) #3
In the mean time to back fill this issue, I built a data directive that will delete the queue items by tran type
Data Directive: MtlQueue->Standard | Remove Select MtlQueue Trans
foreach(var row in ttMtlQueue.Where(x => x.Added() && (x.TranType == "PUR-STK" || x.TranType == "PUR-SUB")))
  using (var txscope = IceDataContext.CreateDefaultTransactionScope())
    var dbrow = Db.MtlQueue.With(LockHint.UpdLock).Where(x => x.MtlQueueSeq == row.MtlQueueSeq).FirstOrDefault();
    Db.MtlQueue.Delete(dbrow);
    Db.Validate();
    txscope.Complete();
Note: Buyer beware, I should have used BOs to delete the records, I didn’t care for the extra overhead on table that’s fairly benign and frankly I was being lazy. BO delete would have been the “right way” vs the way I did it. Conscience decision made to direct delete.
(Mark Damen) #4
@jgiese.wci where have you been all my life?
I’ve posted a couple of times for advice/help in producing exactly this BPM! Thank you for sharing, going to be trying this on my system.
(Mark Damen) #5
Works great on PUR-STK - that takes a load of items out of the queue that we never process.
Struggling on the RMA-INS ones though… for whatever reason, even though this is a standard directive the MtlSeqNo is 0??
I added a bit of code to log into the Epicor App Server the rows in the Data Directive:
foreach(var row in ttMtlQueue)
    Ice.Diagnostics.Log.WriteEntry("MtlQueue Entry " + row.MtlQueueSeq + " has type = *" + row.TranType + "* and RowMod = *" +
                                    row.RowMod + "*");
Any ideas on getting hold of the MtlSeqNo for these tran type?
