We have an important operation that needs to be performed before the next operation should be started. Silly analogy, lets say op 1 is “put oil in the engine” and op 2 is “start the engine”. If you start op 2 without having completed op 1 bad things will happen… To add a bit more complexity say the job is for qty 20, and qty 10 have had op 1 completed, is there a simple way to allow op 2 to be started for 10 but any more will prevent them from starting the op?
In a nutshell we want a way to specify if an operation is required, we want to be able to specify dependencies between operations, and we want Epicor to enforce this somehow. As always we’d prefer to customize Epicor as little as possible…
