I figured it out, set RetrieveOnActivate to false.
*Jose C Gomez*
*Software Engineer*
*T: 904.469.1524 mobile
E: jose@...
http://www.josecgomez.com
*Jose C Gomez*
*Software Engineer*
E: jose@...
On Thu, Mar 24, 2011 at 9:44 AM, Jose Gomez <jose@...> wrote:
> Did you ever find a fix for this? Running into the same problem.
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> <http://www.josecgomez.com/professional-resume/> <http://www.josecgomez.com/feed/>
> On Tue, Mar 2, 2010 at 5:24 PM, jeffery_p_sanders <jps@...
> > wrote:
>> Linda,
>> I did exit EPICOR 9 but it did not help.
>> I also added a comboBox on the Summary sheet. I added 1,2,3,4 as seperate
>> lines in the epiStaticDataList but did not bind it to anything. I set the
>> EpiKeyfield to true. Saved. Exited EPICOR. Restarted. This comboBox disables
>> when I click on it as well.
>> Jeff Sanders
>> --- In vantage@yahoogroups.com, "Linda Lowney" <llowney@...> wrote:
>> > Hi Jeffery,
>> > Did you exit out of Vantage after making the change?
>> > Linda
>> > From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On
>> Behalf
>> > Of jeffery_p_sanders
>> > Sent: Tuesday, March 02, 2010 4:43 PM
>> > To: vantage@yahoogroups.com
>> > Subject: [Vantage] Re: Simple EpiCombo Instructions
>> > It was set to false. I set it to true. No difference. The comboBox looks
>> > enabled until I click on it, then it becomes disabled before showing any
>> > of the items in the list.
>> > This also happens on a comboBox without any fields in the
>> > epiStaticDataList.
>> > I placed a textbox on the form to test, it works correctly.
>> > JPS
>> > --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ,
>> > "Linda Lowney" <llowney@> wrote:
>> > > Jeffery,
>> > > Did you change the EpiKeyField property to True?
>> > > Regards,
>> > > Linda
>> > > From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
>> > [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On
>> > Behalf
>> > > Sent: Tuesday, March 02, 2010 3:23 PM
>> > > To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
>> > > Subject: [Vantage] Simple EpiCombo Instructions
>> > > I've added the epicombo from the toolbox. I've populated the
>> > > epiStaticDataList with about 10 items. I've bound the data to the
>> > > Character20 field of the Quote Header table. When I run Quote Entry,
>> > the
>> > > combobox is disabled. It shows enabled on the custom properties. I
>> > > thought this would be a really easy thing to do. Any ideas?
>> > > [Non-text portions of this message have been removed]
