Hello,
What is the recommended way to push the Epicor Kinetic cloud installer to various PCs on the network?
Any thought are definitely appreciated!
Hello,
This should see you in the righ direction.
The robocopy method works well I have used to to deploy to a 7 branches over a WAN (approx 100 clients), but if it is a fresh install you will not get the Epicor client event log leaf added.
If deploying over a WAN I suggest you locate the files locally then deploy at each site. A bit more hassle, but will save a heap of time.
Hope that helps.
