Hello, newbie here…
I have made some progress learning job scheduling, but have run into an issue I can’t seem to figure out. AFter I run global scheduling, and fill shop capacity, the shop load report PDF shows load against resources correctly. However, when I look at the shop load graph for those same resources, it is not showing any “actual load” at all. Any ideas? Thanks for all the help!
Check this article on EpicCare: KB0099507 there is all info!
I am curious if this procedure works for you @mcharter. I have all but given up on those graphs as then are never correct. But I also don’t regularly run the processes in the KB. Let us know how it works!
No workarounds, just follow the steps in the KB. It should get you there. We don’t use those graphs yet.
well, i figured it out… our test database was reset and all the production parts/hr was set to zero, so no load.
