We too have struggled with the whole Resource Group/Resource
visibility. It was very evident to us that when Epicor came out with
V8 and the separation of Resource Groups and Resources along with
APS/Capabilities...they didn't do a very good job with separating
and breaking down to the Resource level...basic software
functionality and reporting.
I could send you (offline) my baq/dashboard that we use to forecast
load vs capacity. But as Robert Brown posted...the unfortunate is
the Load and Capacity tables are not real-time once an operation is
started. But for forecasting and filling gaps...for the most
part...it works for us. And yes...there will always have to be fine-
tuning to the schedule once all the chips fall after MRP/Global
Scheduling.
Patty Buechler
UV Color
Scheduling.
Patty Buechler
UV Color
--- In vantage@yahoogroups.com, "mdhoge" <mhoge@...> wrote:
> Patty
> My company has been struggling with the whole resource group and
> resource load visability. In theory we have resource groups that
> include resources in which sometime only can run certain parts,
thus
> there is always some manual jockeying of jobs after MRP is run. I
> would be curious to learn more about your custom report, if we have
a
> better understanding of near future load on various spefic
resources,
> it would help us greatly.
> --- In vantage@yahoogroups.com, "bpbuechler" <pbuechler@> wrote:
> > Brad;
> > Three tables:
> > ShopLoad
> > ShopCap
> > ResourceTimeUsed
> > Four things that populate the data to the Resource Schedule Load
> > Graph (above and beyond Job Scheduling or running the Global
> > Scheduling process):
> > 1. Generate Shop Capacity Process (System
Management>Utilities).
> It
> > should be a scheduled process running for however many days you
are
> > interested in seeing Capacity against load. We run it 4 times a
> day
> > as certain times a year we are hitting capacity and need to know
> > where the gaps are to quickly fill them.
> > 2. zScheduleLoadGraph-COMPANYID (Executive Analysis>Business
> > Activity Management>General Operations>Schedule Process Set. The
> > built-in dashboard/graph is connected to executive queries that
> needs
> > to also be processed as a scheduled task.
> > 3. Load Relieved by: Hrs or Qty (System Management>Company
> > Maintenance>Company) Load will remain on an Open job even if the
> > operation is marked complete. In otherwords, if you produce less
> > than the Planned Run Qty or Produce in a shorter timeframe than
> > Planned Hrs (Setup & Production combined). This one is probably
> > causing you the issue. I know it does for us as we consider the
> > operation complete when we hit Planned Production Qty for
> > the operation not the Planned Run Qty.
> > 4. Job Closing/Completion (Production Management>General
> > Operations). Completing a job removes any outstanding load for
> > operations that are not complete and material allocations for
> > materials that are not issued complete.
> > I have spent an extensive amount of time with shop load. I
> actually
> > built my own dashboard that (around the same concept as the
> standard
> > one) splits the graphing to a 6 month snap shot. This provides
our
> > company a more finite view of the load for the first 6 months and
a
> > forecast of the following 6 months. The only thing I could not
get
> > working in a dashboard is to then display the detail job load for
a
> > day/week/month/etc. Since the ResourceTimeUsed.LoadHours is an
> > separated field, you cannot query against it. So we had to build
a
> > new custom report; additionally to provide shop load by Resource
> not
> > Resource Group.
> > I hope this helps...
> > Patty Buechler
> > UV Color
> > --- In vantage@yahoogroups.com, "brychanwilliams"
> > <brychanwilliams@> wrote:
> > > Hi,
> > > In v6.1 I did some investigation on this a long time ago.
> > > One report, contains unreleased load and as well as released.
> > > Firm/Unfirm may play a part as well. The load hours were stored
> in
> > an
> > > array . I think this is why it is a progress report, to aid the
> > > actual calculations per week. To verify this , look at the
tables
> > > involved.
> > > I don't know if it helps.
> > > --- In vantage@yahoogroups.com, "Feakes, Brad" <bfeakes@> wrote:
> > > > My company has been struggling with the Epicor's existing
> capacity
> > > > management tools since we went live in June (we're on 404).
> > > > Specifically, the Resource Schedule Load Graph and the Shop
> Load
> > > report
> > > > are producing different results, in terms of the load
> projections
> > by
> > > > week. In bumping these two reports against other indicators,
> it
> > > would
> > > > appear the Shop Load report is reporting the load projections
> > > > accurately, while the load graph is overstating load, even in
> past
> > > > periods where active jobs no longer exist.
> > > > I understand the Resource Schedule Load Graph to be based on
> some
> > > system
> > > > BAQ's into the ShopLoad and ShopCap tables. Being that the
> Shop
> > > Load
> > > > report is a progress report, I have not been able to "get
under
> > the
> > > > hood" and identify how it is making its calculations, though
my
> > > > assumption is that the logic is different for the two
reports.
> My
> > > > Question-has anyone else out there experienced the same
> situation
> > > where
> > > > the two reports are telling different tales, and does anyone
> know
> > > why
> > > > this might be the case?
> > > > Brad Feakes
> > > > Senior Business Systems Analyst
> > > > Apogee ERP Core Team
> > > > 715-302-5075
> > > > [Non-text portions of this message have been removed]
