Hello,
When I check the “Shipped” checkbox in Customer Shipment entry for a packslip, the ShipHead.ReadyToInvoice will be updated indicating packslip is shipped. This process will also update the OrderRel.ShippingQty on the related Sales Order and Close the Order. After that the “Multi-Company Direct Server Process” will run and I can add the Intercompany Receipt via Receipt Entry in the second company. The problem arises when I replicate the flow of updating the packslip from a Service. In that case the Packslip will be Shipped, but the related Sales Order won’t be affected and the Intercompany receipt wont be visible in the second company. There are no errors in the codes execution
I tried updating and closing the related Sales Order as well, and while this works, the Intercompany receipt is not visible.
The tracelog of the process:
<tracePacket>
<businessObject>Erp.Proxy.BO.CustShipImpl</businessObject>
<methodName>GetPkgCodeQtyList</methodName>
<appServerUri>*******************</appServerUri>
<returnType>System.Void</returnType>
<localTime>08.02.2022 16:29:50:4297319 </localTime>
<threadID>1</threadID>
<correlationId>a4026b6e-511d-4a41-b01f-8a84a166c019</correlationId>
<executionTime total="13" roundTrip="11" channel="0" bpm="0" bpmDataForm="0" other="2" />
<retries>0</retries>
<parameters>
<parameter name="ipPackNum" type="System.Int32"><![CDATA[132954]]></parameter>
<parameter name="opPkgCodeList" type="System.Collections.IList"><![CDATA[]]></parameter>
</parameters>
</tracePacket>
<tracePacket>
<methodName>CheckPCBinOutLocation</methodName>
<localTime>08.02.2022 16:29:50:4447367 </localTime>
<correlationId>cbfe6afe-b4d9-4c3c-8398-53950bf5be54</correlationId>
<executionTime total="26" roundTrip="11" channel="0" bpm="0" bpmDataForm="0" other="15" />
<parameters>
<parameter name="ds" type="Erp.BO.CustShipDataSet">
<CustShipDataSet xmlns="http://www.epicor.com/Ice/300/BO/CustShip/CustShip" />
</parameter>
<parameter name="lineNum" type="System.Int32"><![CDATA[0]]></parameter>
<parameter name="belongToAnotherPC" type="System.Boolean"><![CDATA[False]]></parameter>
<parameter name="pcOutsideMessage" type="System.String"><![CDATA[]]></parameter>
</parameters>
<paramDataSetChanges>
<paramDataSet name="ds" useDataSetNbr="0">
<changedValue tableName="ShipHead" rowState="Modified" rowNum="0" colName="ReadyToInvoice"><![CDATA[True]]></changedValue>
<changedValue tableName="ShipHead" rowState="Modified" rowNum="0" colName="UD_SysRevID"><![CDATA[System.Byte[]]]></changedValue>
</paramDataSet>
</paramDataSetChanges>
</tracePacket>
<tracePacket>
<methodName>UpdateMaster</methodName>
<localTime>08.02.2022 16:29:50:4747357 </localTime>
<correlationId>1b563c4f-232c-40cc-9a18-047041d293d8</correlationId>
<executionTime total="636" roundTrip="625" channel="0" bpm="0" bpmDataForm="0" other="11" />
<parameters>
</parameter>
<parameter name="doValidateCreditHold" type="System.Boolean"><![CDATA[True]]></parameter>
<parameter name="doCheckShipDtl" type="System.Boolean"><![CDATA[True]]></parameter>
<parameter name="doLotValidation" type="System.Boolean"><![CDATA[False]]></parameter>
<parameter name="doCheckOrderComplete" type="System.Boolean"><![CDATA[True]]></parameter>
<parameter name="doPostUpdate" type="System.Boolean"><![CDATA[True]]></parameter>
<parameter name="doCheckCompliance" type="System.Boolean"><![CDATA[False]]></parameter>
<parameter name="ipShippedFlagChanged" type="System.Boolean"><![CDATA[True]]></parameter>
<parameter name="ipBTCustNum" type="System.Int32"><![CDATA[479]]></parameter>
<parameter name="opReleaseMessage" type="System.String"><![CDATA[]]></parameter>
<parameter name="opCompleteMessage" type="System.String"><![CDATA[]]></parameter>
<parameter name="opShippingMessage" type="System.String"><![CDATA[]]></parameter>
<parameter name="opLotMessage" type="System.String"><![CDATA[]]></parameter>
<parameter name="opInventoryMessage" type="System.String"><![CDATA[]]></parameter>
<parameter name="opLockQtyMessage" type="System.String"><![CDATA[]]></parameter>
<parameter name="opAllocationMessage" type="System.String"><![CDATA[]]></parameter>
<parameter name="opPartListNeedsAttr" type="System.String"><![CDATA[]]></parameter>
<parameter name="opLotListNeedsAttr" type="System.String"><![CDATA[]]></parameter>
<parameter name="shipCreditMsg" type="System.String"><![CDATA[]]></parameter>
<parameter name="cError" type="System.Boolean"><![CDATA[False]]></parameter>
<parameter name="compError" type="System.Boolean"><![CDATA[False]]></parameter>
<parameter name="msg" type="System.String"><![CDATA[]]></parameter>
<parameter name="opPostUpdMessage" type="System.String"><![CDATA[]]></parameter>
<parameter name="updateComplete" type="System.Boolean"><![CDATA[False]]></parameter>
<parameter name="checkComplianceError" type="System.Boolean"><![CDATA[False]]></parameter>
<parameter name="changeStatusError" type="System.Boolean"><![CDATA[False]]></parameter>
<parameter name="checkShipDtlAgain" type="System.Boolean"><![CDATA[False]]></parameter>
</parameters>
<changedValue tableName="ShipHead" rowState="Modified" rowNum="0" colName="RowMod"><![CDATA[U]]></changedValue>
</paramDataSet>
</tracePacket>
<tracePacket>
<methodName>BuildShipToList</methodName>
<localTime>08.02.2022 16:29:51:1729466 </localTime>
<correlationId>22a54b52-fd45-4b48-98c3-0e5525d0967d</correlationId>
<executionTime total="36" roundTrip="35" channel="0" bpm="0" bpmDataForm="0" other="1" />
<parameters>
<parameter name="orderNum" type="System.Int32"><![CDATA[121708]]></parameter>
<parameter name="iShipToCustNum" type="System.Int32"><![CDATA[479]]></parameter>
<parameter name="shipToList" type="System.String"><![CDATA[]]></parameter>
</parameters>
</tracePacket>
<tracePacket>
<localTime>08.02.2022 16:29:51:3919621 </localTime>
<correlationId>daf092ec-a7bc-4767-97c3-1e56f599b69b</correlationId>
<executionTime total="40" roundTrip="38" channel="0" bpm="0" bpmDataForm="0" other="2" />
<parameters>
</parameters>
</tracePacket>
<tracePacket>
<methodName>GetByID</methodName>
<returnType>Erp.Tablesets.CustShipTableset</returnType>
<localTime>08.02.2022 16:29:51:4349665 </localTime>
<correlationId>ccb522f4-a61b-4887-b38d-9ff4a518a3d1</correlationId>
<executionTime total="50" roundTrip="46" channel="0" bpm="0" bpmDataForm="0" other="4" />
<parameters>
<parameter name="packNum" type="System.Int32"><![CDATA[132954]]></parameter>
</parameters>
</tracePacket>
and my code
using(var custShipSvc = Ice.Assemblies.ServiceRenderer.GetService<Erp.Contracts.CustShipSvcContract>(Db))
string[] stringForUpdatemaster = new string[12];
bool[] outForUpdateMater = new bool[6];
custShipTS = custShipSvc.GetByID(tempNum);
custShipSvc.BuildShipToCustomerList(tempOrderNum.OrderNum, out creditMsg);
custShipSvc.BuildShipToList(tempOrderNum.OrderNum, tempOrderNum.ShipToCustNum,out shipToList);
System.Collections.IList codeList;
custShipSvc.GetPkgCodeQtyList(shipHeadRow.PackNum, out codeList);
var biTTShipHead3 = BufferCopy.Copy<Erp.Tablesets.ShipHeadRow>(custShipTS.ShipHead[0]);
biTTShipHead3.RowMod = "";
custShipTS.ShipHead.Add(biTTShipHead3);
custShipTS.ShipHead.FirstOrDefault().ReadyToInvoice = true;
custShipTS.ShipHead.FirstOrDefault().RowMod = "U";
custShipSvc.CheckPCBinOutLocation(ref custShipTS, out lineNum, out belongtoAnother, out pcOutsideMessage);
custShipSvc.UpdateMaster(ref custShipTS,false,false,false,false,false,false,false, custShipTS.ShipHead.FirstOrDefault().PackNum, tempOrderNum.BTCustNum, out stringForUpdatemaster[0], out stringForUpdatemaster[1], out stringForUpdatemaster[2], out stringForUpdatemaster[3], out stringForUpdatemaster[4], out stringForUpdatemaster[5], out stringForUpdatemaster[6], out stringForUpdatemaster[7], out stringForUpdatemaster[8], out stringForUpdatemaster[9], out outForUpdateMater[0], out outForUpdateMater[1],out stringForUpdatemaster[10], out stringForUpdatemaster[11],out outForUpdateMater[2],out outForUpdateMater[3],out outForUpdateMater[4],out outForUpdateMater[5]);
Note: This is not the full code, this is the part that doesn’t work. All the variable parameters passed in the methods are valid.
Thanks for the help in advance!
