Shipping label change to label printer
One of you wizards out there knows how to fix this.
On Vantage 5.1 (soon 6.1), Crystal 8.0 (soon 8.5)
The shipping label prints as one of a few labels on an 8.5 x 11 sheet.
We want to switch to a label printer, a continuous roll of labels which print sideways.
In Crystal:
1) I can modify the Printer-Setup to use the correct printer & paper size.
2) Once that is done ALL section Are grayed-out as if 'suppressed'
Even under Format>Section>no-check-in-suppress, they remain gray
3) Have previewed the Epicor default label in Vantage which should give me the table in the vntgwork area
4) Preview in Crystal or Vantage flashes the single label then gives an error.
The printer is a Dymo 330...
Thought this printer was recommended on this list
Thanks for all hints.
Babette Welch
IT Director
Argonics
1110 Wright
Marquette MI 49855
906.226.9747 ext 235
906.228.0951 fax
