Setting up a new sql instance
You specify the database on the "Change the Default Database" prompt.
Progress Properties had to be changed because the Schema Holder Update tool doesn't create them properly. I just copied the propath and workdir settings from MfgSys803. The rest are just performance tuning.
----- Original Message -----
Date: Thursday, February 22, 2007 4:38 pm
Subject: [Vantage] Re: setting up a new sql instance
> thanks for the info.
> so if the app servers and schema holders were created, then just
> create the odbc connection to the 803 test db, and set the app
> properties (which seems to be performance related but possibly
> optional below?). Any particular name the odbc connection
> requires,
> and where does that get set to tell progress "this dsn is for this
> appserver"?
> --- In vantage@yahoogroups.com, "Chris Robisch" <bluewine@...> wrote:
> > Here's some notes I've used in the past when creating MfgTest803 and
> > MfgPilot803 since they weren't created properly on the original 8.03
> > disks for SQL. -new is the name of the new database, like
> MfgPilot803. /
> > between parameters is settings for test/live databases
> > If necessary, run D:\Updates\SchemaHolderUpdateInstall.exe
> > (Manufacturing Systems by Epicor)
> > Enterprise Manager
> > Create -new Database
> > Name -new
> > Collation SQL_Latin1_General_CP1_CI_AS
> > Data File E:\SQLData\MSSQL\Data\-new_Data.MDF
> > Log File E:\SQLData\MSSQL\Data\-new_Log.LDF
> > Change -new Database Properties
> > Options: AutoShrink
> > Restore from Live
> > Create ODBC Connection
> > Create folder E:\Epicor\-new\DB
> > Stop OE Admin Service
> > Copy E:\OE100B\Properties D:\ChrisR\Properties
> > Run Programs\Manufacturing by Epicor\Schema Holder Update Tool
> > New -new
> > V800 E:\Epicor\MfgSys803
> > Open E:\OE100B
> > Progress mfgsyssh (lowercase!!)
> > Directory E:\Epicor\-new\DB
> > Ports (DB App Process Task; 3,1 in TaskAgent)
> > Live 8300-3
> > Train 8310-3
> > Test 8320-3
> > Pilot 8330-3
> > Check AppServer Properties: change propath, workdir
> > Optimization
> > Default Configuration
> > BlocksInDatabaseBuffers=5000/50000
> > LockTableEntries=16384
> > SpinLockRetries=20000/40000 (2/4 cpus)
> > MfgSysGroup
> > MessageBufferSize=4096
> > Parameter Files
> > -lbimod 0 -Mm 4096 -mmax 4000/65534 -Bt 4000/50000 -TB 31 -TM 32
> -D
> 500
> > -I 1000 -s 200 -yy 1970
> > -stsh 31 -inp 32000 -tok 4000
> > UBroker (Agent Pool Range)
> > initialSrvrInstance=1/5
> > maxSrvrInstance=9/20
> > minSrvrInstance=1
> > --- In vantage@yahoogroups.com, "adamtuliper" <amt@> wrote:
> > I installed sql, thats up and running. I now want to get a test
> database
> > going. I copied production and named it MfgTest803. Copies were
> made of
> > the full text catalogs automatically during the copy (ie
> backup/restore
> > as new db). What do I need to setup so progress knows to look for
> > MfgTest803 in the app servers that already exist? This isn't
> listed
> in
> > their install guide.
> > Thanks, Adam
database going. I copied production and named it MfgTest803. Copies
were made of the full text catalogs automatically during the copy (ie
backup/restore as new db). What do I need to setup so progress knows to
look for MfgTest803 in the app servers that already exist? This isn't
listed int heir install guide.
Adam
Sounds like you got MSSQL ready, when you installed 803, did it create a
MfgTest803 app servers and schema holders? Ours did and I didn't do
anything special to do it.
If not, someone else here or Install Support can walk you through creating
the schema holder and app servers. I'm not sure of the process myself.
Randy
_____
adamtuliper
Sent: Thursday, February 22, 2007 4:13 PM
Subject: [Vantage] setting up a new sql instance
Adam
disks for SQL. -new is the name of the new database, like MfgPilot803. /
Enterprise Manager
Name -new
Options: AutoShrink
Restore from Live
New -new
Open E:\OE100B
Live 8300-3
Train 8310-3
Test 8320-3
Pilot 8330-3
Optimization
MfgSysGroup
Parameter Files
-lbimod 0 -Mm 4096 -mmax 4000/65534 -Bt 4000/50000 -TB 31 -TM 32 -D 500
minSrvrInstance=1
--- In vantage@yahoogroups.com, "adamtuliper" <amt@...> wrote:
I installed sql, thats up and running. I now want to get a test database
going. I copied production and named it MfgTest803. Copies were made of
the full text catalogs automatically during the copy (ie backup/restore
MfgTest803 in the app servers that already exist? This isn't listed in
Thanks, Adam
optional below?). Any particular name the odbc connection requires,
appserver"?
MfgPilot803. /
> Enterprise Manager
> Name -new
> Options: AutoShrink
> Restore from Live
> New -new
> Open E:\OE100B
> Live 8300-3
> Train 8310-3
> Test 8320-3
> Pilot 8330-3
> Optimization
> MfgSysGroup
> Parameter Files
500
> minSrvrInstance=1
database
made of
backup/restore
in
> Thanks, Adam
yea.. have the app servers and schema holders, so then whats the next
step? I see there is another post - going to review that now as well
create a
creating
myself.
> Thanks,
> Randy
> _____
Behalf Of
> adamtuliper
(ie
knows to
isn't
> Thanks,
> Adam
