Setting PO due date based on VendorID
Hello all,
Looking for some feedback on how to approach this- When a user enters a new PO, I would like to default the due date for all lines, based on the Vendor ID entered in the header section. For example, when the Vendor ID is “Vendor X”, I would like to default the line’s due date to 2 weeks from today’s date. I am thinking that the trigger for the BPM would be on pressing SAVE?
Can someone guide me as to what BO I need to act upon and whether this would be a PRE or POST processing BPM? I tested on PO.Update to trigger a message box but was unsuccessful. I’m hoping this isn’t an unrealistic approach…
Alice
Try using Tracing, this is available through the main Epicor menu. Clear the trace then do the steps you are wanting to do when the BPM triggers, then review the trace. This will show all the business objects that were used during the steps you did while the trace was on. Be sure to turn tracing off when you are done. Hope this helps.
PO.ChangeVendor method directive. Pre or Post shouldnt matter in this case.
Also, You could do it in a customization onChange of the Vendor.
I may suggest you could have a UDfield On Vendor table with the number of days this supplier needs for delivery. Instead of forcing 2 weeks… (unless 2 weeks is for all of them !)
And I would follow Chris comment as use a custo in the form to have the date right away.
Pierre
The UD field on Vendor table sounds like a great idea. Thank you everyone for ideas. I’m digging back in…
Alice
Just an FYI - there is a LEAD TIME days field on materials in the supplier price list.
it is specific to the supplier and part and must be setup - but it is standard epicor operation
good luck
Humm, forgot about that field… Al is right, that should be the way to go (I asked and that is what we use… :wink: ) It may be more work, but Epicor is using that field in material requirements in job Entry…
Pierre
Thank you, I wasn’t aware of that. About to look into it, as that seems a more functional approach.
As Pierre said, it will require more work for these to be setup but it will be more ‘clean’ if done through Epicor processes rather than a custom BPM.
Here’s the location on the Part entry screen for the Lead Time -
This Lead Time field is pretty much exactly what you’re looking for. As Al said, it is also located in Supplier Price List - which is where you can start the setup process for the specific vendors and parts.
