I have customizations applied to the Process Payments and Restart Process Payments check print screens. Applying the customization to Process payments is easy enough through Menu Maintenance, but I can’t figure out how to apply it to Restart Process Payments. I’ve created a menu item, and set the ID in Process Calling Maintenance, but in Menu Maintenance the the customization cannot be selected. Restart Process Payments uses Erp.UIRpt.ProcessPayment.dll, but with Rpt.ProcessPayment.RestartProcPaymentForm
I even tried adding the -c argument to the menu item through an updatable BAQ, but it has no effect and Epicor removes the argument on next restart.
