Set current date on field using BPM
Thank you very much for your reply. I'll try that.
Jeff
--- In vantage@yahoogroups.com, "NigelK" <nigel.kerley@...> wrote:
> Hi Jeff,
> I think you'd have to use a 4GL action to do this.
> The code would be something like:
> Find first ttOrderDtl where ttOrderDtl.RowMod = "U" or ttOrderDtl.RowMod = "A" no-lock no-error.
> If available ttOrderDtl then assign ttOrderDtl.Date01 = TODAY.
> HTH,
> Nigel.
> --- In vantage@yahoogroups.com, "jefferson112296" <jefferson112296@> wrote:
> > Vantage 8.03.408
> > Here's what I want to do with a BPM.
> > Action: the ttOrderDtl.CheckBox05 field has been changed from False to True
> > Condition: set the OrderDtl.Date01 field of the changed row to the Specific value
> > Where Specific is the date that the checkbox was checked.
> > Can someone tell me if it is possible to put the current date (date the box was checked) in for the value? If so, what would the syntax be?
> > Jeff Kusiciel
> > IT Manager
> > PLITEK
Vantage 8.03.408
Jeff Kusiciel
IT Manager
PLITEK
Hi Jeff,
HTH,
Nigel.
--- In vantage@yahoogroups.com, "jefferson112296" <jefferson112296@...> wrote:
> Vantage 8.03.408
> Jeff Kusiciel
> IT Manager
> PLITEK
