I am struggling with creating a workflow to Add Sales Order and Lines. I am following a Main-Sub Workflow Approach where I am creating a Order Hed in Main WF and trying to create Lines in SUB WF.
Following is my CSV format:
I have achieved to generate Order Num and is able to pass it to Process Variable however, I am not able to iterate my Sub WF to create the Order Lines. and the WF Finishes as follows:
Not sure, why not the underlying Sub WF elements are being hit ?
Have you thought about using DMT with the Sales Order Combined template and Powershell to import data rather than Service Connect? Far simpler if you are not a Developer. 1PartLoad.zip (307 Bytes)
Check on the data being passed into the Sub workflow call: most likely cause here feels like it’s not being given any data to pass down.
Generally for this approach you’d store the input document to a message extension in the first step of workflow, store the order number to a process variable after the UpdateExt call and then restore the input document from extension to /msg/req/dta node before calling your sub-workflow.
Sub-workflow would then have the “Cycling execution” box ticked to call it for each line of your data: adding the lines 1 by 1.
Passing Data to Container works for me. This was the step that I missed completely.
One Question, that, is this container capable to hold Large amount of Input Data ?
