Service Connect workflow triggered by BPM
The bpm passes the data set of the method you just fired that trigger the
BPM. There is an instruction set in the files section on how to extract this
data set and be able to use it in your workflow. If you need any help
understanding it let me know I wrote it.
In short no you don't need an input channel, message type, and or message
map.
~Charlie
_____
Rob Bucek
Sent: Thursday, October 29, 2009 6:01 PM
Subject: RE: [Vantage] Service Connect workflow triggered by BPM
No message map, input channel or message type is needed. Theoretically
your input schema should be the response schema of the method you're
coming from in your first conversion element (which should be the first
element in your work flow). In your case the input schema would be
custshipservice/UpdateRequest.
Your document tracking cant be seen under inbound messages, you need to
look under all activities/completed activities. Make sure in your work
flow under process properties you set tracing status to required under
the document tracking tab.
If you have trouble with your schema you may have to just pass it
through a conversion straight to a poster out to a file folder. Grab
the xml output and feed it back into your schema utility to generate a
new schema. Sometimes there are some discrepancies between the schema
coming out of the BPM and what the web service schema is. Just be aware
of this possibility.
Rob Bucek
Manufacturing Engineer
PH: (715) 284-5376 ext 3111
FAX: (715)284-4084
<http://www.dsmfg <http://www.dsmfg.com/> com/>
(Click the logo to view our site) <http://www.dsmfg <http://www.dsmfg.com/>
com/>
From: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
[mailto:vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com] On
Behalf
Of Matt Caldwell
Sent: Thursday, October 29, 2009 4:43 PM
To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
Subject: [Vantage] Service Connect workflow triggered by BPM
When you use a BPM to trigger a workflow, do you need to setup the
message map, input channel, and message type? In that workflow, I
have an Input schema of CustShipService/UpdateRequest.xsd. Then I
wrote the packnum to a process variable. Do I need an output schema to
capture the trace details from the BPM?
When I trigger the BPM, I don't see the workflow. I do see the
"informal message" box that I put in my actions, so I know that it is
triggering.
Any ideas?
Matt Caldwell
Technical Support Analyst
KERUSSO
P.O. Box 32
Berryville, AR 72616
Phone: 800-424-0943 Ext. 295 or 870-480-4530
Fax: 870-423-3568
Web Site: http://www.kerusso <http://www.kerusso.com> com
CONFIDENTIALITY STATEMENT:
This message, from Kerusso Inc., contains information
which is privileged and confidential and is solely for the use of
the intended recipient. If you are not the intended recipient, be
aware that any review, disclosure, copying, distribution, or use
of the contents of this message is strictly prohibited. If you have
received this in error, please destroy it and notify us immediately
at: 800-424-0943
triggering.
Any ideas?
Matt Caldwell
KERUSSO
P.O. Box 32
Fax: 870-423-3568
Web Site: http://www.kerusso.com
at: 800-424-0943
Rob Bucek
FAX: (715)284-4084
(Click the logo to view our site) <http://www.dsmfg.com/>
Of Matt Caldwell
triggering.
Any ideas?
Matt Caldwell
KERUSSO
P.O. Box 32
Fax: 870-423-3568
at: 800-424-0943
