Thanks for all of the help on this one everybody. I eventually found a
way to make it work but it wasn't by using any trickery in SC. I just
talked to the configurator programmer and she was willing to change all
of the JOBDONE operation sequences to the same number... I should have
talked to her a while ago.
Blake Clemens
IT Systems Engineer
Delmarva Millwork Corporation
(800) 360-2364 x132
Of Cathlene Fishman
Sent: Wednesday, August 19, 2009 11:36 AM
Subject: [Vantage] Re: Service Connect Workflow Question
Blake, I'm not totally clear on what you need because I do no have
access to the web service you are referring to ...
however, if you need to set a value in the request to the last
OperSeqNum then your xslt would look something like ...
value-of select="OperSeqNum[last()] ...
if the last seq num is not the highest num ... then you will need to
sort them and then get the last ....
hope that helps ...
Cathlene
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Of Cathlene Fishman
hope that helps ...
Cathlene
>I'll
> All,
> I am working on a SC workflow and ran into a problem. I am trying to
> automate the Labor Entry process. I am caught at the point where you
> select the OperSeq on the Labor/Detail tab. This number is always the
> last possible number in the list but we don't always have the same
> numbers in the list. I need to know is there any way to program the
> workflow to select the last number in the list? I am using the
> LaborService.DefaultOpeSeq webservice. Any Ideas or thoughts would be
> greatly appreciated. If I'm being too vague please let me know and
> supply more information.[Non-text portions of this message have been removed]
> Thanks,
> Blake Clemens
> IT Systems Engineer
> (800) 360-2364 x132
