Machzy
(Mach Zreik)
1
We created a workflow through Service Connect for PO approvals. Got this error message a few times though and I can’t figure out what the problem is:
<?xml version="1.0" encoding="utf-16" standalone="yes"?>
<msg:req tag=“POApvMsg.Erp.Proxy.BO.POApvMsgImpl.GetByID”>
msg:ers
<msg:error type=“unexpected error”>
msg:number2147220990</msg:number>
msg:description- Record not found.
</msg:description>
msg:source- Ice.Common.RecordNotFoundException at Epicor.ServiceModel.Channels.ImplBase`1.ShouldRethrowNonRetryableException(Exception ex, DataSet[] dataSets)
</msg:source>
</msg:error>
</msg:ers><msg:dta xmlns:msg=“http://Epicor.com/InternalMessage/1.1”><ext_GetByIDRequest:Erp_Proxy_BO_POApvMsgImpl_GetByID_Request xmlns:ext_GetByIDRequest=“http://Epicor.com/POApvMsg/Erp_Proxy_BO_POApvMsgImpl_GetByID_Request”><ext_GetByIDRequest:CompanyID>09</ext_GetByIDRequest:CompanyID><ext_GetByIDRequest:poNum>129</ext_GetByIDRequest:poNum></ext_GetByIDRequest:Erp_Proxy_BO_POApvMsgImpl_GetByID_Request></msg:dta>msg:ctxtrue</msg:ctx>msg:wfl<msg:usr xmlns:msg=“http://Epicor.com/InternalMessage/1.1”>msg:ChannelInfo<ext_Pop3:Pop3 xmlns:ext_Pop3=“http://epicor.com/schemas/ChannelInfo/Pop3”>
(There’s more, but it contains the employees name, email, etc.)
Any ideas on what it means?
Machzy
(Mach Zreik)
2
Actually, there’s two errors. Here’s the second one:
<?xml version=“1.0” encoding=“utf-16” standalone=“yes”?><msg:msg xmlns:xsi=“http://www.w3.org/2001/XMLSchema-instance” xsi:schemaLocation=“http://Epicor.com/InternalMessage/1.1 http://scshost/schemas/epicor/ScaInternalMsg.xsd” xmlns:msg=“http://Epicor.com/InternalMessage/1.1”>
<msg:req tag=“POApvMsg.Erp.Proxy.BO.POApvMsgImpl.CheckApprovalLimit”>
<msg:ers>
<msg:number>2147220990</msg:number>
<msg:description>- There is an error in XML document (1, 370). - Input string was not in a correct format.
</msg:description>
<msg:source>- System.InvalidOperationException at System.Xml.Serialization.XmlSerializer.Deserialize(XmlReader xmlReader, String encodingStyle, XmlDeserializationEvents events) - System.FormatException at System.Number.StringToNumber(String str, NumberStyles options, NumberBuffer& number, NumberFormatInfo info, Boolean parseDecimal)
</msg:source>
</msg:error>
</msg:ers><msg:dta xmlns:msg=“http://Epicor.com/InternalMessage/1.1”><ext_CheckApprovalLimitRequest:Erp_Proxy_BO_POApvMsgImpl_CheckApprovalLimit_Request xmlns:ext_CheckApprovalLimitRequest=“http://Epicor.com/POApvMsg/Erp_Proxy_BO_POApvMsgImpl_CheckApprovalLimit_Request”><ext_CheckApprovalLimitRequest:CompanyID>09</ext_CheckApprovalLimitRequest:CompanyID><ext_CheckApprovalLimitRequest:vAprvAmt></ext_CheckApprovalLimitRequest:vAprvAmt><ext_CheckApprovalLimitRequest:vApproved>APPROVED</ext_CheckApprovalLimitRequest:vApproved></ext_CheckApprovalLimitRequest:Erp_Proxy_BO_POApvMsgImpl_CheckApprovalLimit_Request></msg:dta><msg:ctx><CompanyCode></CompanyCode><InfoMessageAsErr>true</InfoMessageAsErr></msg:ctx><msg:wfl><msg:usr xmlns:msg=“http://Epicor.com/InternalMessage/1.1”><msg:ChannelInfo><ext_Pop3:Pop3 xmlns:xsi=“http://www.w3.org/2001/XMLSchema-instance” xmlns:ext_Pop3=“http://epicor.com/schemas/ChannelInfo/Pop3”>
