I have added a new field on the OrderHed table, regenerated the data model and recycled the application pool. In Service connect the new field is not appearing on the field list on the .xslt conversion. How can I get this to appear, without losing the current conversion ?
Hi Emma,
If you added a UD field to Kinetic, you need to re-import BO reference(s) in Service Connect, making sure the Import UD Fields checkbox is selected during the import.
That will update schemas for the re-imported references according to the latest database structure.
Yes, thank you!
