Service Connect Input Channel Won't Disable
I am trying to disable an Input Channel and it won’t disable. It has been over 10 mins and it still shows Enabled on the Input Channel Screen If I look at the Properties of the input channel, it shows disabled. I tried dropping a file in that input channel and it pulled the file even though it is disabled.
Any suggestions or thoughts?
