Service Connect---Delete Operation
(system) #1
Great that did the trick. rowmod=[DELETE] thanks! And i see that Web Services Developer Guid.pdf now. I need to have those couple of pages, that is valuable stuff. Thanks for the input!!
---In vantage@yahoogroups.com, <ygroups.adamleer@...> wrote:
Look at the "Web Services Developer Guid.pdf" in your Epicor server installation directory.  For us, it is here on the Epicor server:
E:\Epicor905\WebServices\
You may have to interpret.  It has a FAQ section which includes how to delete a row, how to clear a column, how to set the Plant AND Company in the current call context, etc.  Good read.
---In vantage@yahoogroups.com, <rbucek@...> wrote:
You just do an update method, hard code RowMod to be [DELETE] with the brackets
Rob Bucek
Production Control Manager
PH: (715) 284-5376 ext 311
Mobile: (715)896-4832
FAX: (715)284-4084
[cid:1.234354861@...]<http://www.dsmfg.com/>
(Click the logo to view our site)<http://www.dsmfg.com/>
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of daniellaidig@...
Sent: Friday, October 11, 2013 1:37 PM
Subject: [Vantage] Service Connect---Delete Operation
I am writing a service connect workflow to delete specific operations within engineering workbench. There is a webservice DeleteByID but that is only to delete the ECO group. There is no inputs for operation. I ran a trace on the delete operation within vantage and didn't discover much useful information except that an Update webservice was used. Can anyone shed some light on how to delete an operation via Service Connect and Vantage 8. I have tried RowMod = 'D' But that didn't work either.... :(
Thank in advance
Daniel
(system) #2
Thank in advance
Daniel
(system) #3
<!-- #ygrps-yiv-1380698776 _filtered #ygrps-yiv-1380698776 {font-family:Wingdings; panose-1:5 0 0 0 0 0 0 0 0 0;} _filtered #ygrps-yiv-1380698776 {font-family:Wingdings; panose-1:5 0 0 0 0 0 0 0 0 0;} _filtered #ygrps-yiv-1380698776 {font-family:Calibri; panose-1:2 15 5 2 2 2 4 3 2 4;} _filtered #ygrps-yiv-1380698776 {font-family:Tahoma; panose-1:2 11 6 4 3 5 4 4 2 4;} _filtered #ygrps-yiv-1380698776 {font-family:Verdana; panose-1:2 11 6 4 3 5 4 4 2 4;} _filtered #ygrps-yiv-1380698776 {font-family:Consolas; panose-1:2 11 6 9 2 2 4 3 2 4;} #ygrps-yiv-1380698776 #ygrps-yiv-1380698776 p.ygrps-yiv-1380698776MsoNormal, #ygrps-yiv-1380698776 li.ygrps-yiv-1380698776MsoNormal, #ygrps-yiv-1380698776 div.ygrps-yiv-1380698776MsoNormal {margin:0in; margin-bottom:.0001pt; font-size:12.0pt; font-family:"Times New Roman", "serif";} #ygrps-yiv-1380698776 a:link, #ygrps-yiv-1380698776 span.ygrps-yiv-1380698776MsoHyperlink { color:blue; text-decoration:underline;} #ygrps-yiv-1380698776 a:visited, #ygrps-yiv-1380698776 span.ygrps-yiv-1380698776MsoHyperlinkFollowed { color:purple; text-decoration:underline;} #ygrps-yiv-1380698776 p {
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
font-family:“Times New Roman”, “serif”;}
#ygrps-yiv-1380698776 code
font-family:“Courier New”;}
#ygrps-yiv-1380698776 pre
margin:0in;
font-size:10.0pt;
#ygrps-yiv-1380698776 tt
#ygrps-yiv-1380698776 span.ygrps-yiv-1380698776HTMLPreformattedChar
font-family:“Consolas”, “serif”;}
#ygrps-yiv-1380698776 p.ygrps-yiv-1380698776attach, #ygrps-yiv-1380698776 li.ygrps-yiv-1380698776attach, #ygrps-yiv-1380698776 div.ygrps-yiv-1380698776attach
margin-right:0in;
margin-left:0in;
font-size:9.0pt;
font-family:“Arial”, “sans-serif”;}
#ygrps-yiv-1380698776 p.ygrps-yiv-1380698776bold, #ygrps-yiv-1380698776 li.ygrps-yiv-1380698776bold, #ygrps-yiv-1380698776 div.ygrps-yiv-1380698776bold
margin-right:0in;
margin-left:0in;
font-size:10.0pt;
font-weight:bold;}
#ygrps-yiv-1380698776 p.ygrps-yiv-1380698776green, #ygrps-yiv-1380698776 li.ygrps-yiv-1380698776green, #ygrps-yiv-1380698776 div.ygrps-yiv-1380698776green
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
color:#628C2A;}
#ygrps-yiv-1380698776 p.ygrps-yiv-1380698776replbq, #ygrps-yiv-1380698776 li.ygrps-yiv-1380698776replbq, #ygrps-yiv-1380698776 div.ygrps-yiv-1380698776replbq
margin:3.0pt;
font-size:12.0pt;
#ygrps-yiv-1380698776 p.ygrps-yiv-1380698776ad, #ygrps-yiv-1380698776 li.ygrps-yiv-1380698776ad, #ygrps-yiv-1380698776 div.ygrps-yiv-1380698776ad
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
#ygrps-yiv-1380698776 p.ygrps-yiv-1380698776underline, #ygrps-yiv-1380698776 li.ygrps-yiv-1380698776underline, #ygrps-yiv-1380698776 div.ygrps-yiv-1380698776underline
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
#ygrps-yiv-1380698776 span.ygrps-yiv-1380698776yshortcuts
#ygrps-yiv-1380698776 p.ygrps-yiv-1380698776ad1, #ygrps-yiv-1380698776 li.ygrps-yiv-1380698776ad1, #ygrps-yiv-1380698776 div.ygrps-yiv-1380698776ad1
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
#ygrps-yiv-1380698776 p.ygrps-yiv-1380698776ad2, #ygrps-yiv-1380698776 li.ygrps-yiv-1380698776ad2, #ygrps-yiv-1380698776 div.ygrps-yiv-1380698776ad2
margin-right:0in;
margin-bottom:7.5pt;
margin-left:0in;
font-size:12.0pt;
#ygrps-yiv-1380698776 p.ygrps-yiv-1380698776underline1, #ygrps-yiv-1380698776 li.ygrps-yiv-1380698776underline1, #ygrps-yiv-1380698776 div.ygrps-yiv-1380698776underline1
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
#ygrps-yiv-1380698776 span.ygrps-yiv-1380698776yshortcuts1
font-family:“Verdana”, “sans-serif”;
font-weight:bold;}
#ygrps-yiv-1380698776 span.ygrps-yiv-1380698776yshortcuts2
font-weight:normal;}
#ygrps-yiv-1380698776 span.ygrps-yiv-1380698776EmailStyle34
font-family:“Calibri”, “sans-serif”;
color:#1F497D;}
#ygrps-yiv-1380698776 .ygrps-yiv-1380698776MsoChpDefault
font-size:10.0pt;}
margin:1.0in 1.0in 1.0in 1.0in;}
#ygrps-yiv-1380698776 div.ygrps-yiv-1380698776WordSection1
font-family:Symbol;}
font-family:Wingdings;}
#ygrps-yiv-1380698776 ol
{margin-bottom:0in;}
#ygrps-yiv-1380698776 ul
Try row mod = [DELETE], I use this for another SC workflow…
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of daniellaidig@…
Subject: [Vantage] Service Connect—Delete Operation
I am writing a service connect workflow to delete specific operations within engineering workbench. There is a webservice DeleteByID but that is only to delete the ECO group. There is no inputs for operation. I ran a trace on the delete operation within vantage and didn’t discover much useful information except that an Update webservice was used. Can anyone shed some light on how to delete an operation via Service Connect and Vantage 8. I have tried RowMod = ‘D’ But that didn’t work either… :frowning:
Thank in advance
Daniel
(system) #4
Rob Bucek
FAX: (715)284-4084
Thank in advance
Daniel
(system) #5
Rob Bucek
FAX: (715)284-4084
Thank in advance
Daniel
