Service connect and BPM
Thanks!!
Rob Bucek
Manufacturing Engineer
PH: 715-284-5376 ext 311
FAX: 715-284-4084
<http://www.dsmfg.com/>
(Click the logo to view our site)
Of Michelle de la Vega
Sent: Monday, March 23, 2009 12:35 PM
Subject: RE: [Vantage] service connect and BPM
Rob,
Be sure that in the communication properties for the output file the
conversion type is int2ext.
Michelle de la Vega
Business Applications Manager
Cold Jet, LLC
455 Wards Corner Road
Loveland, Ohio 45140
USA
+1 513-716-6400 (office)
+1 513-382-3281 (mobile)
+1 513-831-1209 (fax)
www.coldjet.com<http://www.coldjet.com <http://www.coldjet.com> >
[cid:image001.jpg@01C9ABBC.1D903080
<mailto:image001.jpg%4001C9ABBC.1D903080> ]
Behalf Of rob.bucek
Sent: Friday, March 20, 2009 4:10 PM
Subject: [Vantage] service connect and BPM
Im tryin to do a bpm that calls a workflow using receipt.update. it
appears to be working in some fashion, when i do a receipt i get a file
in my output folder (for now i just simply pass it to a poster). However
there is absolutely no data in the document. Just a shell of an xml
file. Has anyone tried this before? What should i be looking for?
Thanks!
Im tryin to do a bpm that calls a workflow using receipt.update. it appears to be working in some fashion, when i do a receipt i get a file in my output folder (for now i just simply pass it to a poster). However there is absolutely no data in the document. Just a shell of an xml file. Has anyone tried this before? What should i be looking for? Thanks!
Rob,
Be sure that in the communication properties for the output file the conversion type is int2ext.
Michelle de la Vega
Cold Jet, LLC
USA
www.coldjet.com<http://www.coldjet.com>
[cid:image001.jpg@01C9ABBC.1D903080]
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of rob.bucek
