I have some workers trying to use the MES and are getting this error. We have tried restarting the machine and reinstalling the MES to that machine. No other machines affected.
Server Side Exception
Session is invalid. Session has either timed out or has been deleted. You must login again to continue.
Error Detail
Description: Session is invalid. Session has either timed out or has been deleted. You must login again to continue.
Program: Epicor.ServiceModel.dll
Method: .ctor
Line Number: 5
Column Number: 9
Server Trace Stack: at Ice.Common.InvalidSessionException…ctor() in c:_Releases\ICE\3.1.400.19\source\Shared\Framework\Epicor.ServiceModel\Exceptions\InvalidSessionException.cs:line 5
at Ice.Hosting.SessionCache.Get[T](Guid sessionID) in c:_Releases\ICE\3.1.400.19\source\Framework\Epicor.Ice\Hosting\SessionCache.cs:line 31
at Erp.Extensibility.SessionProvider.ErpSessionBuilder.GetSession(Guid sessionID) in c:_Releases\ERP\RL10.1.400.0\Source\Server\Internal\Extensibility\SessionProvider\ErpSessionBuilder.cs:line 31
at Epicor.Hosting.CallContext.Create(Operation op) in c:_Releases\ICE\3.1.400.19\source\Framework\Epicor.Ice\Hosting\CallContext.cs:line 200
at Ice.Security.AuthorizationManager.CheckAccess(OperationContext operationContext, Message& message) in c:_Releases\ICE\3.1.400.19\source\Framework\Epicor.Ice\Security\AuthorizationManager.cs:line 73
at System.ServiceModel.Dispatcher.AuthorizationBehavior.Authorize(MessageRpc& rpc)
at System.ServiceModel.Dispatcher.ImmutableDispatchRuntime.ProcessMessage11(MessageRpc& rpc)
at System.ServiceModel.Dispatcher.MessageRpc.Process(Boolean isOperationContextSet)
at System.ServiceModel.Dispatcher.ChannelHandler.DispatchAndReleasePump(RequestContext request, Boolean cleanThread, OperationContext currentOperationContext)
at System.ServiceModel.Dispatcher.ChannelHandler.HandleRequest(RequestContext request, OperationContext currentOperationContext)
at System.ServiceModel.Dispatcher.ChannelHandler.AsyncMessagePump(IAsyncResult result)
at System.Runtime.Fx.AsyncThunk.UnhandledExceptionFrame(IAsyncResult result)
at System.Runtime.AsyncResult.Complete(Boolean completedSynchronously)
at System.ServiceModel.Channels.TransportDuplexSessionChannel.TryReceiveAsyncResult.OnReceive(IAsyncResult result)
at System.ServiceModel.Channels.SynchronizedMessageSource.ReceiveAsyncResult.OnReceiveComplete(Object state)
at System.ServiceModel.Channels.SessionConnectionReader.OnAsyncReadComplete(Object state)
at System.Net.LazyAsyncResult.Complete(IntPtr userToken)
at System.Net.Security.NegotiateStream.ProcessFrameBody(Int32 readBytes, Byte[] buffer, Int32 offset, Int32 count, AsyncProtocolRequest asyncRequest)
at System.Net.Security.NegotiateStream.ReadCallback(AsyncProtocolRequest asyncRequest)
at System.Net.FixedSizeReader.CheckCompletionBeforeNextRead(Int32 bytes)
at System.Net.FixedSizeReader.ReadCallback(IAsyncResult transportResult)
at System.ServiceModel.Channels.ConnectionStream.IOAsyncResult.OnAsyncIOComplete(Object state)
at System.ServiceModel.Channels.SocketConnection.OnReceiveAsync(Object sender, SocketAsyncEventArgs eventArgs)
at System.Net.Sockets.SocketAsyncEventArgs.FinishOperationSuccess(SocketError socketError, Int32 bytesTransferred, SocketFlags flags)
at System.Net.Sockets.SocketAsyncEventArgs.CompletionPortCallback(UInt32 errorCode, UInt32 numBytes, NativeOverlapped* nativeOverlapped)
at System.Threading._IOCompletionCallback.PerformIOCompletionCallback(UInt32 errorCode, UInt32 numBytes, NativeOverlapped* pOVERLAP)
Client Stack Trace
at Epicor.ServiceModel.Channels.ImplBase`1.ShouldRethrowNonRetryableException(Exception ex, DataSet[] dataSets)
at Erp.Proxy.BO.EmpBasicImpl.GetRows(String whereClauseEmpBasic, String whereClauseEmpBasicAttch, String whereClauseEmpLabExpRate, String whereClauseEmpCal, String whereClausePartner, String whereClauseResourceCal, String whereClauseEmpRole, String whereClauseEntityGLC, String whereClauseEmpRoleRt, Int32 pageSize, Int32 absolutePage, Boolean& morePages)
at Erp.Adapters.EmpBasicAdapter.OnGetRows(SearchOptions opts, Boolean& MorePages, String[] whereClauses)
at Ice.Lib.Framework.EpiBaseAdapter.GetRows(SearchOptions opts, Boolean& morePages)
at Ice.Lib.Searches.EpiSearchEngine.SearchUsingAdapterMethod(SearchOptions options)
at Ice.Lib.Searches.EpiSearchEngine.SearchIt(SearchOptions options, DataSet& results, Boolean& usedAdapter)
at Ice.Lib.Searches.EpiSearchEngine.SearchIt(SearchOptions options)
at Ice.Lib.Framework.EpiBaseAdapter.InvokeSearch(SearchOptions opts)
at Erp.Menu.Mes.Transa
