Gary
If I read your response correctly you only have 16 GB of hard disk
space....I'm still on 6.0 with 135 users. In the past three years my DB
has grown from 2.4 GB to 11.25 GB. I would recommend MORE hard disk
space available. I don't know your number of users and volume but my
grows at a 100 MB a month rate.
Cliff
Of Mark Turner
Sent: Wednesday, September 19, 2007 7:45 AM
Subject: Re: [Vantage] Server Performance from upgrades
Gary,
We are new customers and will not go live until May 08. We are running
dual Quad Zeons at 2Ghz with a 1333FSB. We are running the 64 bit
Windows Server 2003 Standard. As long as it is the 64 bit version, then
Standard can still access more than 4GB of memory. (We have 16GB) Raid
10 gives you fault tollerance and better speed. We went with the 15K SAS
drives, but I don't know what the difference would have been with 10K.
Mark Turner
----- Original Message ----
<mailto:cliff%40massprecision.com> >
Sent: Wednesday, September 19, 2007 10:20:05 AM
Subject: RE: [Vantage] Server Performance from upgrades
Gary
You might lay your hands on Windows Standard Server 2008.. RC1 is due
out any time now. The standard version is supposed to support 64 bit
address space. Basically unlimited ram.
Cliff
____________ _________ _________ __
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On
Behalf
Of fvrm1510
Sent: Thursday, September 13, 2007 12:41 PM
To: vantage@yahoogroups .com
Subject: [Vantage] Server Performance from upgrades
We are still looking for a performance increase even though we did
gain from some of your responses on performance issues a few weeks
ago (thanks to all who helped!) As a reminder we are running
Vantage 8.0 with a likely transition to 8.03 at the end of the
year.
We are currently looking at upgrading server hardware and would like
to have some input as to what improvements if any would be gained
from our current configuration.
We are currently running on one server with Vantage 8.00 & have
approximately 20 users on the system. Our operating system is
Windows Server 2000 with two Intel Xeon 2.8 GHz/1MB processors, 800
MHz FSB, & 3.4 GB of ram running at 400MHZ. We are running Raid 1
with two hard drives that run at 10,000 rpm.
New server/s that we are considering would have two Intel Quad Core
Xeon processors 2x4MB Cache, 2.66Ghz, 1333Mhz FSB. The unit/s would
have at least 8 GB 677MHz of ram.
We would appreciate advice/recommendati ons on the following:
We would like to go to Windows Server 2003.
A. We are considering installing either the Standard version or the
Enterprise version of Windows Server 2003. Can anyone make
recommendation as to possible advantages of one system over the
other?
B. When 64 bit technology is eventually supported in Vantage, can
anyone tell us if there would be a performance advantage from one
operating system to the other?
C. Our active directory is currently on the same server as Vantage -
is anyone doing this or is there a performance advantage to having
this on a different server?
The new Server/s have hard drives that run at 15,000 rpm and there
is enough drives to configure Raid 10.
A. Would we likely see any performance increase in Vantage 8 with
the faster hard drive speeds?
B. What if any performance improvements would we gain in a Raid 10
environment vs our current raid 1 configuration?
Gary Khulanek
Fasse Valves
308.233.2040
or email to dlabrayere@fasse. com <mailto:dlabrayere% 40fasse.com>
__________________________________________________________
Looking for a deal? Find great prices on flights and hotels with Yahoo!
FareChase.
http://farechase.yahoo.com/ <http://farechase.yahoo.com/>
Cliff
Of Mark Turner
Gary,
Mark Turner
Gary
Cliff
Behalf
Of fvrm1510
year.
other?
Gary Khulanek
Fasse Valves
308.233.2040
FareChase.
