I am relatively new to functions and raised a ticket with Epicor a few months ago as when I used the Log Message widget, or added custom code to write to the server log the messages were not showing. The function will run but the Server Log doesn’t show the message.
Am I doing something wrong as I have been advised by Epicor \ Development that everything works as it should. They showed me the server log showing the function had run and even though it didn’t show the message they said it was correct.
So I guess my question is: Is there a better way for me to track each stage of my function\bpm than the original way I was taught in Vantage using log messages?
Hi. Yes, that is exactly what I use in Data\Method directives but if I use it in a function (even just a function with only that line of code!) it doesn’t show in the Server Log
Thanks but unfortunately that’s not my issue as it’s not creating \ saving function that is the problem but that the message doesn’t actually show in the server log. Appreciate the link though
Thanks Andrew. Appreciate the information and am aware I can connect onto the server and review the logs but it’s just easier to open the server log with Notepad on my client!
