I have been told that E10.1.500.46 will not run on Server 2019, is that true?
10.1.500 came out before Server 2019, so that version of Epicor is never going to be “certified” for Server 2019… but that doesn’t mean it “won’t run”. It just means that if you do run into some fluke compatibility issue, you’re probably out of luck in terms of Epicor supporting the issue…
