Hi,
I set up a serial tracked kit with a generating sequential mask serial number and we track the components within the serial tracked kit. When I try to receive in the kit the “add” button is not active to generate the serial number. However, if I do a quantity adjustment it allows me to click the “add” button and it will generate the next new number for me.
What am I missing in the set up to have the serial number auto generate when I try to perform the job to inventory receipt?
Thank you
Serial numbers get created in the Serial Number Assignment window.
So whenever you try to do a Job receipt to Inventory, and you go to select serial numbers, you wont be able to create it there. You would need to go to Serial Number Assignment window and in there you would be able to generate the Serial Numbers.
