We are starting to use Track Serial Numbers. When you turn on a part for Track serial number and click Serial Number format. Is that the format all part will use or can each part have its own format?
so we have part ABC set up to this
but part XYZ I would like it to use a serial mask
Can every part be set up to use a different serial format if needed?
