Hello,
Any one able to help me understand… WTF this table is doing?
It works perfectly on PO Receipt, Quantity Adjustment.
It’s just container receipt and dropship that it’s being a royal… ARSEHOLE!!
Hello,
I’ll have to admit, the memes almost got me, but I’m not screwing with serial numbers today.
I guess I am not sure what the problem is. You imported a bunch of Serial Numbers, do you have to move them to Selected
? Not sure if its a bug your facing or just a, incorrect usage of the Screen.
Probably incorrect use of screen.
Anyone able to help me figure this one out?
Go into classic and see if those serial numbers you imported are actually there and are valid.
See if it works there.
Might as well trace while you’re there in case something is wrong (or right), then maybe you can see what’s up.
I’ve got a feeling that SerialNumberSelection
might be the wrong table to be putting the data into.
A lot of other posts use SelectedSerialNumbers
- I will try this tomorrow redefining the tables and see what happens…
A lot of time and effort has gone into this and from other people. I don’t want to give up now. I can then post a fully working solution for someone else to save their sanity!
Second this.
Well some sort of progress…
29 now out of 30… Almost there…
Now it’s skipping the first one… but the import brings in 30 and transfers 30 to the correct tables…
Classic reports 29…
Show everything you got.
