Serial Number History Of Part
Hi All
I’m looking to make a BAQ which will show me the history of parts and what version they are to do this i was thinking Serial number as the part numbers change from v1 to v2 v3 but Im not sure the best way to do this. Or the other question is dose Epicor do this out of the box?
I believe the table is SNTransactions. It’s the data that shows on the Serial Number Tracker > Transactions (classic) or Serial Number Tracker > Activity > Trans card in Kinetic.
If you just want to look up transactions on 1 serial number you can use the out-of-box tracker. Otherwise I would start a BAQ with the SNTransactions table.
