Please self-qualify and respond to agnes@... only if you are a good fit
Senior EPICOR Specialist in Stratford, CT (full-time permanent position)
Basic Responsibilities
An Epicor expert to handle day to day system stability and performance optimization for a highly customized system in a high volume lean manufacturing environment. Determine requirements, solutions and execution of process improvements as it relates to ERP activities. Must be able to multi-task with good communication skills.
Specialized knowledge, expertise and or abilities concisely required.
B.S. in Computer Science/ Software Engineering
Preferred Master degree in CS or related field
3 plus years Epicor Vantage 8.03.4xx and/or Epicor 9.05 in a manufacturing environment.
3 plus years DBA experience with Microsoft SQL Server 2005/2008 including data warehouse design
CRM, AMM, Engineering, QA, SRM, EDI MRP, Multi-Site AR/AP/GL modules
Progress OpenEdge configuration and optimization including Sonic MQ
Expert with Advanced and Embedded Customizations primarily with BPM (Progress 4GL) and .Net
Custom form design, BAQ, dashboards, executive dashboards, DMT tool
Though knowledge of Epicor datasets and client server dataflow
Product Configurator
Epicor Service Connect Workflows and Web Services development and execution
Crystal Report writer with Report Data Definitions and configuration with Altec, APM
Epicor Portal and MS SharePoint development and administration
Citrix, Customer/Supplier Connect, Agile Manifest CorVu and FRx a plus
www.rjsassociates.com
