Security/MES Integration Options
Yes you can do this fairly easily via customization or you could go with Active Directory SSO.....
A scenario would be find / buy / implement an active directory authentication plug in / software that allows you to sing onto a machine using your badge (there are many of these)
Then setup Epicor to use SSO.
Another option would be to customize Epicor and have a badge reader of sorts that you can use as a lookup to authenticate the application though that might require some customization of the application.
Jose C Gomez
Software Engineer
T: 904.469.1524 mobile
On Fri, Sep 18, 2015 at 9:30 AM, sambisegamgi1@... [vantage] <vantage@yahoogroups.com> wrote:
Â
<div>
  <p></p><p style="margin-top:12px;margin-bottom:12px;outline:0px;font-family:Arial, Verdana, geneva, sans-serif;vertical-align:baseline;background:transparent;">Building Security - We are looking at implementing a badge swipe or RFID tag to gain admittance and log entrance/exit. Depending on the product/software we use for this, can this entrance/exit data be transferred into MES? Ideally, I’d like for people to use this system to get in and out of the building and not have to also log in and clock out of MES. We are using version 9.05.702. Any possible options are welcomed.</p><p><span></span></p><p style="margin-top:12px;margin-bottom:12px;outline:0px;font-family:Arial, Verdana, geneva, sans-serif;vertical-align:baseline;background:transparent;">Thank you</p><p><span><br></span></p><p></p>
</div>
<div style="color:#fff;min-height:0;"></div>
Thank you
