We are just testing Kinetic screens and in many cases we are finding a limitation where we can only return (and select) 250 rows from a record search. We are finding this an issue at the moment in PO Suggestions (New and change). But it seems to be a restriction in other areas too. Does anyone know if it is possible to override this limitation or if it is something EPICOR will address in the future?.
Kinetic is a bit like a chocolate fireguard with these limits in place?
You’re lucky! We can only get 50 rows at a time with Kinetic Job Status Maintenance. Maybe you bought the ‘Advanced Kinetic Search’ upgrade that gets you 250 rows.
Submit a ticket and use the feedback fly-out every chance you get. Kinetic still is a step back and more steps/clicks compared to Classic at this point in time (on 2021.2 here), but it does get closer to feature-parity every new major release.
My idea to work around this was to use a BAQ Search instead.
The result is a 404 error. I reported to EPICOR support and they confirmed it is a known problem and is it is better not to use BAQ Searches in this release.
