I must be missing something. I have a UD02 table and have created a
BAQ for it and put everything in the like column. I then create a
quick search, but the quick search only returns a single column and
not the whole record. Also, the BAQ is not available in the Named,
Quick Search, or BAQ section of the Search Form.
--- In vantage@yahoogroups.com, Robert Brown <robertb_versa@...>
wrote:
the visible fields as search accessible 'like' columns.
search for that form if you desire.
wrote:
>limiting criteria desired for your search. Make sure to set up all
> Write a BAQ to present the layout, column header titles & any
> Ânamed "Named Search" that uses your BAQ. You can make it the default
> Then, for your UD form search, just create a more intuitively
>how
> --- On Tue, 6/10/08, egarbowski <egarbowski@...> wrote:
> From: egarbowski <egarbowski@...>
> Subject: [Vantage] Search customization
> To: vantage@yahoogroups.com
> Date: Tuesday, June 10, 2008, 11:49 AM
> Are the Search forms customizable within the UD forms, and if so,
> can they be accessed? I've customized the UD01 form and am onlyusing 2
> fields from the UD01 table, but the Search form displays everyfield
> from the UD01 table using the default field names as headings.
> Any help in pointing me in the right direction is much appreciated.
> Ed
