Feeling pretty brain dead myself Mark. :)
(What a week! Felt like 2.)
Rob
--- Original Message ---
Sent:Fri 6/12/09 5:09 pm
To:<vantage@yahoogroups.com>
Subj:RE: [Vantage] Re: Search add columns
Thanks for the help Rob..at first I read your response on my phone and I
thought you said I was brain dead....kinda feel like it today.
Of Robert Brown
Sent: Thursday, June 11, 2009 1:05 PM
Subject: Re: [Vantage] Re: Search add columns
Mark,
The wizard is brain dead. Save your BAQ (and export to xml for good
measure), clear the BAQ from the wizard & reload it.
You should then see all fields (except calc fields) available for
searches.
...Also be sure the BAQ is public and shared!
Rob
From: rapat_mark <mtellefson@... <mailto:mtellefson%40rapat.com> >
Sent: Thursday, June 11, 2009 11:28:55 AM
Subject: [Vantage] Re: Search add columns
I am trying to use the instructions below to add a new search to the
quote entry screen. I am using the "Character01" field to hold our own
quote number to help get past the problem of Vantage's inability to have
quote revisions. I have a BAQ with the quote number, quote date, and
character01 for fields and no filtering. When I do the Analyze I get the
3 columns as expected but when I go to the BAQ Search tab there are no
"Available Like Columns" to select. Am I missing something? I am on
8.03.305k.
Mark
--- In vantage@yahoogroups .com, Robert Brown <robertb_versa@ ...>
wrote:
right BAQ search tab in the BAQ wizard) so they can be used in searches.
default search for the target app if applicable.
Rob
Of Robert Brown
Mark,
searches.
Rob
8.03.305k.
Mark
wrote:
>search. Make it public and shared & also move all your columns (via far
> Charlie,
> Write yourself a BAQ that contains the info you want displayed in your
>search. For good measure, make it a named search and set it to be the
> In your application, you should then be able to select that BAQ as a
>doing
> Rob Brown
> ____________ _________ _________ __
> From: Charlie Wilson <foamdesigncsw@ ...>
> To: vantage@yahoogroups .com
> Sent: Wednesday, June 3, 2009 1:41:07 PM
> Subject: [Vantage] Search add columns
> I need to add some columns of info to a search box how do I go about
> that?[Non-text portions of this message have been removed]
> ~Charlie
