Screen customization help
To make sure that fields remain hidden, we have had to remove the
epibinding for that field to make sure it stayed hidden....
Of Robert Brown
Sent: Wednesday, April 02, 2008 1:31 PM
Subject: Re: [Vantage] Screen customization help
Nope - The 'band aid' (move controls entirely off the viewable sheet) is
the only one that ALWAYS works.
Some controls - even when set to not Visible, become visible when a
field or event they are tied to triggers them to wake up.
Some controls allow you to change them from Enabled to Disabled (along
with making them Hidden). Try Disabling them along with making them
Hidden.
You also want to be sure you set them so they aren't in the Tabstop
sequence.
I suggest NEVER decoupling the control from its native data view... That
almost always results in "Object missing" app load errors.
Rob Brown
brad_boes <bboes@... <mailto:bboes%40metalworks1.com> >
wrote:
We are implementing Vantage 8.03.404a and would like to customize
several screens.
When we go to customize the screens, it seems difficult to
hide "extra" buttons, fields and such.
We can remove them from the screen in design mode, but after saving
the new settings the extra unwanted fields or buttons re-appear,
sometimes on top, underneath or overlapping other items. It is
frustrating for something that should be pretty simple to do.
We have been told to move these items in location off the standard
screen as a bandaid.
Any other tricks to making these changes stick?
Thanks in advance. I watch this dialog daily and appreciate
everyone's cooperation to help each other on these items.
Brad Boes
Metalworks
You rock. That's why Blockbuster's offering you one month of Blockbuster
Total Access, No Cost.
several screens.
Brad Boes
Metalworks
The only way I 've found is to just move the fields off of the screen. I
have tried to make the field visible property = false but it doesn't
seem to work
Kersten MacLennan
IT/ERP Analyst
Semrock, Inc.
3625 Buffalo Rd.,
Suite 6
Rochester, NY 14624
585-594-7009
585-594-7095 fax
kmaclennan@...
The Standard in Optical Filters for Biotech & Analytical Instrumentation
Hundreds of Thousands of Ion Beam Sputtered filters delivered -
extensive inventory now!
The information contained in this message and any attachments may be
privileged, confidential, and protected from disclosure. If the reader
of this message is not the intended recipient, or any agent responsible
for delivering this message to the intended recipient, you are hereby
notified that any dissemination, distribution, or copying of this
communication may be unlawful and therefore strictly prohibited. If you
received this message in error, please reply to the message and delete
it. Thank you
Of brad_boes
Sent: Wednesday, April 02, 2008 10:36 AM
Subject: [Vantage] Screen customization help
several screens.
Brad Boes
Metalworks
If you are having difficulties, setting the size to 0,0 will always
work.
Of brad_boes
Sent: 02 April 2008 15:36
several screens.
Brad Boes
Metalworks
Nope - The 'band aid' (move controls entirely off the viewable sheet) is the only one that ALWAYS works.
Some controls - even when set to not Visible, become visible when a field or event they are tied to triggers them to wake up.
Some controls allow you to change them from Enabled to Disabled (along with making them Hidden). Try Disabling them along with making them Hidden.
You also want to be sure you set them so they aren't in the Tabstop sequence.
I suggest NEVER decoupling the control from its native data view... That almost always results in "Object missing" app load errors.
Rob Brown
several screens.
Brad Boes
Metalworks
You rock. That's why Blockbuster's offering you one month of Blockbuster Total Access, No Cost.
