Thanks, I will give that a try.
One more thing, in Epicor 9 this object Epicor.Mfg.UI.Rpt.ARInvForm.Transaction is used for invoice printing. What is the object should that is the replacement for this in Epicor 10?
I tried this Erp.UIRpt.ARInvForm.Transaction (making a reference to Erp.UIRpt.ARInvForm) but get error that UIRpt is not a part of Erp.
If the controls youâre talking about are Key fields, I believe youâll find posts here that say the best way to âhideâ them is to move them off screen with a really high or negative x,y values
On EpicWeb for your version there will be ERP_BO_Ref_10.x.xxx file that will have the BOs. You should also be able to find doing a trace of the process. Use the BL Tester to figure out the call.
If this existed in E9 did it fail getting converted?
In E9, the object was Epicor.Mfg.UI.Rpt.ARInvForm.Transaction. What I would like to know, is what is the replacement for this object in E10, so that I can use it to do Batch Invoice Printing.
Okay, I will be trying the suggestion of @gpayne first and if that doesnât work, then I will try your suggestion.
To find that you will need to run the mass print in AR Invoice entry with tracing on and then you can use the Trace Parser that @josecgomez made at the link below to find the object. Then use the BL Tester to work out the calls needed.
Thank you. Trying this today.
It was mentioned earlier that this is a UD form, and that the main controls canât be made not visible.
Is that the extent of your issues?
Can you export the Customization then post it here?
Or at least show screen shots of what it looks like in developer mode, and what you see when launched in normally.
There are 2 issues:
This is the UD form controls not showing my changes when I exit customization and go back in. The screen would go back to its original layout. I have been trying to use the visible property to hide the controls II do not need and @gpayne suggested using code to hide them instead. @Mark_Wonsil suggested moving the controls off screen. Will be trying @gpayne suggestion first and see how that works.
This one is about reference object. As mentioned above, I am trying to find the E10 replacement for an E9 object ( Epicor.Mfg.UI.Rpt.ARInvForm.Transaction) and that is what @gpayne is referring to.
This solution did work. As all of the controls returned to their original position.
Try this Roy
I will look into this.
So this has been resolve.
As a novice in Epicor, and thinking as a VS developer, I did not realize that if there are errors in the code when the screen loads, all screen changes revert back to default. Lesson learned, lesson not soon forgot.
Thank you everyone for your help.
Very much appreciated.
As mentioned before never remove UD key fields it will screw up the form interactions entirely. They must remain visible = true. How you deal with them otherwise as far as a user is concerned matters not (size, location)
Background on why the errors (unlike in VS stop the screen from loading), when you open a customization it compiles the code on the fly (exactly like build in VS) and saves the compiled customization to your local cache folder. This is one example of why a decent processor is required for client workstations, they are doing code compile builds on their actual machine. Imagine running VS builds on an Intel i3⌠it would be horribly slow, enter slow initial screen loads (when it says âDownloading from Databaseâ). This is why if a change isnât recognized, customizations can get âstuckâ as an older version and you have to clear cache.
Thank you everyone, I was able to get pass the initial issues with help.
I continue to have other issues with the AR Batch Printing. I have been able to get a list of invoices however, it is not doing the filtering based on Customer selected, so I am getting the entire database list of invoices.
I have attached the entire code here. The issue I am having seems to start in function btnSearch_Click(). Thanks in advance for your help.
// Custom code for UD110Form
// Created: 10/17/2014 2:43:06 PM
using System;
using System.ComponentModel;
using System.Data;
using System.Diagnostics;
using System.Windows.Forms;
using Ice.Lib;
using Erp.BO;
using Ice.BO;
using Ice.Proxy.BO;
using Ice.UI;
using Ice.Adapters;
using Erp.Adapters;
using Ice.Lib.Customization;
using Ice.Lib.ExtendedProps;
using Ice.UI.FormFunctions;
using Ice.Lib.Framework;
using Ice.Lib.Searches;
using Infragistics.Win.UltraWinGrid;
using Infragistics.Win.UltraWinProgressBar;
using System.Collections;
using System.Collections.Generic;
using System.Net.Mail;
using System.IO;
using System.Threading;
using System.Reflection;
public static class Script
// ** Wizard Insert Location - Do Not Remove âBegin/End Wizard Added Module Level Variablesâ Comments! **
private static Ice.Core.Session session;
static InvcPrinter invcPrinter;
static Hashtable custContacts; // Contacts for each customer
//static Hashtable custInvoices; // emailed invoices for each customer (table row's DataRow)
static UD110Adapter ud110adapter;
static CustCntAdapter custCntAdapter;
static UltraProgressBar progressBar;
static string dataDir, serverDir;
static object crystalRpt; // ReportDocument
static string crystalRptFile;
static PrintDialog dialog;
static Thread thread;
static bool threadAborted = false;
static string action; // PRINT, PDF or MAIL
static Assembly crystalEngine, crystalShared;
static bool KeepGeneratedFiles;
private static string lastCustID="";
public static void InitializeCustomCode()
epiCheckEmailCopySelf.Checked=true;
baseToolbarsManager.ToolClick += new Infragistics.Win.UltraWinToolbars.ToolClickEventHandler(baseToolbarsManager_ToolClick);
UD110Form.Closing += new System.ComponentModel.CancelEventHandler(UD110Form_Closing);
Script.buttonShipTo.Click += new System.EventHandler(Script.buttonShipTo_Click);
Script.buttonCustomer.Click += new System.EventHandler(Script.buttonCustomer_Click);
Script.txtCustID.LostFocus += new System.EventHandler(Script.txtCustID_LostFocus);
Script.btnSearch.Click += new System.EventHandler(Script.btnSearch_Click);
Script.buttonEmail.Click += new System.EventHandler(Script.buttonEmail_Click);
Script.buttonPrint.Click += new System.EventHandler(Script.buttonPrint_Click);
Script.buttonCloseContactList.Click += new System.EventHandler(Script.buttonCloseContactList_Click);
Script.btnContinue.Click += new System.EventHandler(Script.btnContinue_Click);
session = (Ice.Core.Session)oTrans.Session;
// Hide tree
((Infragistics.Win.UltraWinDock.WindowDockingArea)csm.PersonalizeCustomizeManager.ControlsHT["UD110Form.windowDockingArea1"]).Visible = false;
//csm.GetNativeControlReference("46c8ee42-a6f1-468b-95ba-6dfc13223ee2").Parent.Parent.Visible = false;
//csm.GetNativeControlReference("42ddcd10-9993-46f8-86e5-de797a96c3b8").Parent.Visible = false;
KeepGeneratedFiles = false;
invcPrinter = new InvcPrinter(oTrans);
custContacts = new Hashtable();
//custInvoices = new Hashtable();
custCntAdapter = new CustCntAdapter(oTrans);
custCntAdapter.BOConnect();
ud110adapter = new UD110Adapter(oTrans);
ud110adapter.BOConnect();
DataRow row;
try {
ud110adapter.GetByID("INVOICE_MAILER","SUBJECT_BODY","","","");
row = ud110adapter.UD110Data.UD110.Rows[0];
} catch {
ud110adapter.GetaNewUD110();
row = ud110adapter.UD110Data.UD110.Rows[ud110adapter.UD110Data.UD110.Rows.Count-1];
row["Key1"] = "INVOICE_MAILER";
row["Key2"] = "SUBJECT_BODY";
row["Character01"] = "CAToronto shipment invoices";
row["Character02"] = "Good day. Attached you will find invoice(s) for shipments. "
+ "Please email the sender OR your customer service rep with any discrepancies.";
ud110adapter.Update();
//MessageBox.Show("loaded UD110"); //DEBUGGING CODE
// Add Progress Bars to status panel
progressBar = new UltraProgressBar();
Control statusBar = oTrans.StatusPanel.UltraStatusBar;
int w = statusBar.Width, h = statusBar.Height;
progressBar.Location = new System.Drawing.Point(500,3);
progressBar.Size = new System.Drawing.Size(200, h-6);
//MessageBox.Show("Prepped progressBar"); //DEBUGGING CODE
progressBar.Step = 1;
progressBar.Text = "Files processed: "+UltraProgressBar.LABEL_VALUE;
//progressBar.Visible = false;
//MessageBox.Show("Set ProgressBar incrementals"); //DEBUGGING CODE
statusBar.Controls.Add(progressBar);
//MessageBox.Show("Added progressbar to astatus bar"); //DEBUGGING CODE
//MessageBox.Show("Process to 'InitializeCustomCode' complete."); //DEBUGGING CODE
public static void DestroyCustomCode()
baseToolbarsManager.ToolClick -= new Infragistics.Win.UltraWinToolbars.ToolClickEventHandler(baseToolbarsManager_ToolClick);
UD110Form.Closing -= new System.ComponentModel.CancelEventHandler(UD110Form_Closing);
Script.buttonShipTo.Click -= new System.EventHandler(Script.buttonShipTo_Click);
Script.buttonCustomer.Click -= new System.EventHandler(Script.buttonCustomer_Click);
Script.txtCustID.LostFocus -= new System.EventHandler(Script.txtCustID_LostFocus);
Script.btnSearch.Click -= new System.EventHandler(Script.btnSearch_Click);
Script.buttonEmail.Click -= new System.EventHandler(Script.buttonEmail_Click);
Script.buttonPrint.Click -= new System.EventHandler(Script.buttonPrint_Click);
Script.buttonCloseContactList.Click -= new System.EventHandler(Script.buttonCloseContactList_Click);
Script.btnContinue.Click -= new System.EventHandler(Script.btnContinue_Click);
// Begin Custom Code Disposal
ud110adapter.Dispose();
custCntAdapter.Dispose();
// End Custom Code Disposal
private static void baseToolbarsManager_ToolClick(object sender, Infragistics.Win.UltraWinToolbars.ToolClickEventArgs args)
if (args.Tool.Key == "ClearTool") {
//txtInvcStart.Value = txtInvcEnd.Value = dteStartDate.Value = dteEndDate.Value = txtCustomer.Value = null;
txtCustID.Text = "";
lastCustID = "";
numericCustNum.Value = 0;
txtShiptoNum.Text="";
gridHeader.DataSource = new DataTable();
gridHeader.Refresh();
gridDetails.DataSource = new DataTable();
gridDetails.Refresh();
//gridDetails.Text = "";
gridContacts.DataSource =new DataTable();
groupContactSelector.Visible = false;
private static void UD110Form_Closing(object sender, System.ComponentModel.CancelEventArgs args)
if (thread != null && thread.IsAlive) {
DialogResult res = EpiMessageBox.Show("A print job is running. Abort?", "", MessageBoxButtons.YesNo);
args.Cancel = (res == DialogResult.No);
if (args.Cancel) {
threadAborted = true;
thread.Abort();
private static void txtCustID_LostFocus(object sender, System.EventArgs args)
if (string.Compare(lastCustID, txtCustID.Text.Trim(), true)==0) return;
groupContactSelector.Visible=false;
if (txtCustID.Text.Trim().Length<= 0)
lastCustID = "";
return;
bool recSelected;
string whereClause = "CustId = '" + txtCustID.Text.Trim() + "'";
SearchOnCustomerAdapterShowDialog(whereClause , false);
private static void buttonCustomer_Click(object sender, System.EventArgs args)
////////////DEBUGGING CODE ⌠BELOW//////////////////
// string s=ââ;
// foreach (System.Windows.Forms.Control c in UD110Form.Controls)
// if (c.HasChildren) {
// s+= c.Name + " [ children? " + c.HasChildren.ToString() + " ] " + Environment.NewLine;
// foreach (System.Windows.Forms.Control c1 in c.Controls)
// if (c1.HasChildren)
// s+= " - "+ c1.Name + Environment.NewLine;
// foreach (System.Windows.Forms.Control c2 in c1.Controls)
// if (c2.HasChildren)
// s+= " >> "+ c2.Name + Environment.NewLine;
// MessageBox.Show(s);
// MessageBox.Show(
// ((System.Windows.Forms.Control)groupContactSelector).Parent.Name + Environment.NewLine +
// ((System.Windows.Forms.Control)groupContactSelector).Parent.Parent.Name + Environment.NewLine +
// ((System.Windows.Forms.Control)groupContactSelector).Parent.Parent.Parent.Name + Environment.NewLine
////////////DEBUGGING CODE ⌠ABOVE//////////////////
SearchOnCustomerAdapterShowDialog();
private static void SearchOnCustomerAdapterShowDialog()
SearchOnCustomerAdapterShowDialog(string.Empty, true);
private static void SearchOnCustomerAdapterShowDialog(string WhereClause, bool showSearchWindow)
bool recSelected;
string whereClause = WhereClause; //string.Empty;
//SearchFunctions.listLookup Call belongs to : Ice.UI.FormFunctions.SearchFunctions.listLookup
DataSet dsCustomerAdapter = SearchFunctions.listLookup(oTrans, "CustomerAdapter", out recSelected, showSearchWindow, whereClause);
if (recSelected)
int custNum=0;
System.Data.DataRow adapterRow = dsCustomerAdapter.Tables[0].Rows[0];
// Map Search Fields to Application Fields
try
if (!int.TryParse(adapterRow["CustNum"].ToString(), out custNum)) custNum = 0;
if (custNum>0)
numericCustNum.Value = custNum;
// string str=ââ; //DEBUGGING CODE
// for (int tc = 0; tc < dsCustomerAdapter.Tables[0].Columns.Count; tc++) //DEBUGGING CODE
// { //DEBUGGING CODE
// str +=dsCustomerAdapter.Tables[0].Columns[tc].ColumnName + " | "; //DEBUGGING CODE
// } //DEBUGGING CODE
// MessageBox.Show (str); //DEBUGGING CODE
// MessageBox.Show("EDVROW: " + adapterRow[âCustNumâ].ToString());} //DEBUGGING CODE
try{
txtCustID.Text = adapterRow["CustId"].ToString();
if (string.Compare(lastCustID, txtCustID.Text.Trim(), true)!=0)
lastCustID = txtCustID.Text;
btnSearch_Click(txtCustID, new System.EventArgs());
catch{}
catch{}
private static void buttonShipTo_Click(object sender, System.EventArgs args)
SearchOnShipToAdapterShowDialog();
private static void SearchOnShipToAdapterShowDialog()
bool recSelected;
string whereClause = string.Empty;
if (txtCustID.Text.Trim().Length> 0)
whereClause = "CustNum = " + numericCustNum.Value.ToString() ;
System.Data.DataSet dsShipToAdapter = Ice.UI.FormFunctions.SearchFunctions.listLookup(oTrans, "ShipToAdapter", out recSelected, true, whereClause);
if (recSelected)
System.Data.DataRow adapterRow = dsShipToAdapter.Tables[0].Rows[0];
try{MessageBox.Show("EDVROW: " + adapterRow["ShipToNum"].ToString());}
catch{}
try{txtShiptoNum.Text = adapterRow["ShipToNum"].ToString();}
catch{}
private static void SearchOnCustContactsAdapterShowDialog(bool showSearchWindow)
bool recSelected;
DataSet dsContactsAdapter = SearchFunctions.listLookup(oTrans, "CustCntAdapter", out recSelected, showSearchWindow, whereClause);
if (recSelected)
int custNum=0;
System.Data.DataRow adapterRow = dsContactsAdapter.Tables[0].Rows[0];
try
MessageBox.Show("EDVROW: " + adapterRow["Name"].ToString());
catch{}
private static void btnSearch_Click(object sender, System.EventArgs args)
if (txtCustID.Text.Trim().Length == 0 && txtShiptoNum.Text.Trim().Length == 0)
MessageBox.Show("Please select a customer!");
return;
SetStatusText("Retrieving data...");
string BAQ = session.CompanyID + "-ARInvoice_Mailer_Head";
try
DynamicQueryAdapter queryAdapter = new DynamicQueryAdapter(oTrans);
queryAdapter.BOConnect();
queryAdapter.GetDashboardQuery(BAQ);
//DataView dv = new DataView(queryAdapter.RuntimeQuery.Tables["QueryTable"]);
DataView dv = new DataView(queryAdapter.QueryResults.Tables["QueryTable"]); // by Roy
//DataView dv = new DataView(queryAdapter.QueryResults.Tables["Results"]); // by ROY
string filter ="";
//filter = AddFilter("", "InvcHead.InvoiceNum>=", txtInvcStart.Text, false);
//filter = AddFilter(filter, "InvcHead.InvoiceNum<=", txtInvcEnd.Text, false);
//filter = AddFilter(filter, "InvcHead.InvoiceDate>=", dteStartDate.Value, true);
//filter = AddFilter(filter, "InvcHead.InvoiceDate<=", dteEndDate.Value, true);
// if (!cbxNotPosted.Checked)
// filter = AddFilter(filter, âInvcHead.Posted=â, true, false);
// if (!cbxNotReadyToCalc.Checked)
// filter = AddFilter(filter, âInvcHead.ReadyToCalc=â, true, false);
// dv.RowFilter = âDataTableName=âInvcHeadââ;
// dv[0][âWhereClauseâ] = filter;
if (txtCustID.Text.Trim().Length > 0)
//MessageBox.Show (dv.Count.ToString());
//dv.RowFilter = String.Format("Customer_CustID = '{0}'", txtCustID.Text.Trim());
filter = AddFilter("", "Customer_CustID=", txtCustID.Text.Trim(), true); //txtCustomer.Text, true);
//MessageBox.Show (filter);
// dv.RowFilter = âDataTableName=âCustomerââ;
//dv[0][âWhereClauseâ] = filter;
dv.RowFilter = filter;
// if (txtShiptoNum.Text.Trim().Length > 0)
// filter = AddFilter(ââ, âInvcDtl.ShipToNum=â, txtShiptoNum.Text.Trim(), true);
// dv.RowFilter = âDataTableName=âInvcDtlââ;
queryAdapter.ExecuteBAQDataViewQuery(queryAdapter.RuntimeQuery);
DataTable dt = queryAdapter.QueryResults.Tables["Results"];
//dt.Columns["Mailed"].Caption = "PDF";
gridHeader.DataSource = dt;
// Disable updating on the entire grid except first column
for (int i=1; i < gridHeader.DisplayLayout.Bands[0].Columns.Count; i++) {
gridHeader.DisplayLayout.Bands[0].Columns[i].CellActivation = Activation.ActivateOnly;
gridHeader.DisplayLayout.Bands[0].Columns["InvcHead_InvoiceSuffix"].Hidden = true;
gridHeader.DisplayLayout.Bands[0].Columns["InvcHead_Company"].Hidden = true;
gridHeader.DisplayLayout.Bands[0].Columns["InvcHead_CustNum"].Hidden = true;
gridHeader.DisplayLayout.Bands[0].Columns["InvcHead_ReadyToCalc"].Hidden = true;
gridHeader.DisplayLayout.Bands[0].Columns["InvcHead_Posted"].Hidden = true;
gridHeader.DisplayLayout.Bands[0].Columns["InvcHead_CheckRef"].Hidden = true;
gridHeader.DisplayLayout.Bands[0].Columns["Customer_CustID"].Hidden = true;
gridHeader.DisplayLayout.Bands[0].Columns["InvcHead_DocInvoiceAmt"].Hidden = true;
gridHeader.DisplayLayout.Bands[0].Columns["InvcHead_InvoiceBal"].Hidden = true;
gridHeader.DisplayLayout.Bands[0].Columns["InvcHead_InvoiceHeld"].Hidden = true;
gridHeader.DisplayLayout.Bands[0].Columns["InvcHead_CurrencyCode"].Hidden = true;
gridHeader.DisplayLayout.Bands[0].Columns["InvcHead_ApplyDate"].Hidden = true;
gridHeader.DisplayLayout.Bands[0].Columns["InvcHead_DepositAmt"].Hidden = true;
gridHeader.DisplayLayout.Bands[0].Columns["InvcHead_InvoiceRef"].Hidden = true;
queryAdapter.Dispose();
SetStatusText("Ready. " + dt.Rows.Count + " records found.");
////////// LOAD Customer Contacts! //////////////////
SearchOptions opts = new SearchOptions(SearchMode.AutoSearch);
opts.SelectMode= SelectMode.MultiSelect; //Ice.Lib.Searches.
opts.DataSetMode = DataSetMode.ListDataSet; //Ice.Lib.Searches.
bool more;
opts.NamedSearch.WhereClauses[âCustCntâ] = âCustNum=â + numericCustNum.Value.ToString();//+invoice[âInvcHead.CustNumâ]; //[âCustomer.CustNumâ];
custCntAdapter.ClearData();
// DataRow[] contacts = custCntAdapter.GetRows(opts, out more).Tables[0].Select(âPrimaryBilling=trueâ);
// if (contacts.Length == 0) {
// MessageBox.Show(âInvoice â+invoice[âInvcHead.InvoiceNumâ]+â, Customer â+custID+â: No Billing contact.â);
// return null;
// if ((string)contacts[0][âEmailAddressâ] == ââ) {
// MessageBox.Show(âInvoice â+invoice[âInvcHead.InvoiceNumâ]+â, Customer â+custID+â: No Email address for Billing contact.â);
// return null;
// custContacts[custID] = new Contact((int)invoice[âInvcHead.InvoiceNumâ], custID, (string)contacts[0][âNameâ], (string)contacts[0][âEmailAddressâ]);
DataTable conTable=new DataTable();
conTable.Columns.Add("Selected", typeof(bool));
conTable.Columns.Add("CustNum",typeof(string)); // typeof(int));
conTable.Columns.Add("CustNumCustID",typeof(string)); // typeof(int));
conTable.Columns.Add("ShipToNum",typeof(string)); // typeof(int));
conTable.Columns.Add("Name",typeof(string)); // typeof(string));
conTable.Columns.Add("EMailAddress",typeof(string)); // typeof(string));
conTable.Columns.Add("PrimaryBilling",typeof(bool));
conTable.Columns.Add("PrimaryPurchasing", typeof(bool));
conTable.Columns.Add("PrimaryShipping", typeof(bool));
//MessageBox.Show ("Columns added to Con Table!!"); // DEBUGGING CODE
for (int c = 0; c < conTable.Columns.Count; c++) {conTable.Columns[c].AllowDBNull = true;}
//MessageBox.Show ("Contacts Table columns set to nullable!!"); // DEBUGGING CODE
DataTable t = custCntAdapter.GetRows(opts, out more).Tables[0];
//MessageBox.Show ("Got Rows from ContactsAdapter!!!!"); // DEBUGGING CODE
try
using (CustomerAdapter custAdapter = new CustomerAdapter(oTrans))
custAdapter.BOConnect();
opts.NamedSearch.WhereClauses["Customer"] = "CustNum=" + numericCustNum.Value.ToString();//+invoice["InvcHead.CustNum"]; //["Customer.CustNum"];
using (DataTable custTable = custAdapter.GetRows(opts, out more).Tables[0])
if (custTable.Rows.Count > 0)
// string strCust =ââ; //DEBUGGING CODE
// for (int ct = 0; ct < custTable.Columns.Count;ct++) //DEBUGGING CODE
// strCust +=custTable.Columns[ct].ColumnName + " | "; //DEBUGGING CODE
// MessageBox.Show (strCust); //DEBUGGING CODE
conTable.Rows.Add(new object[] {
false,
numericCustNum.Value,
txtCustID.Text,
â** default **â,
custTable.Rows[0][âNameâ].ToString(),
custTable.Rows[0][âEMailAddressâ].ToString(),
false,
false,
false
} catch{}
try
for (int r = 0; r < t.Rows.Count; r++)
false,
t.Rows[r]["CustNum"].ToString(),
t.Rows[r]["CustNumCustID"].ToString(),
t.Rows[r]["ShipToNum"].ToString(),
t.Rows[r]["Name"].ToString(),
t.Rows[r]["EMailAddress"].ToString(),
t.Rows[r]["PrimaryBilling"],
t.Rows[r]["PrimaryPurchasing"],
t.Rows[r]["PrimaryShipping"]
} catch (Exception excep) {
MessageBox.Show ("Exception Adding rows to new table!!!" + Environment.NewLine + excep.Message); }
//MessageBox.Show ("Columns added to Con Table!! or were they??"); // DEBUGGING CODE
// gridContacts.DataSource = custCntAdapter.GetRows(opts, out more).Tables[0]; //custCntAdapter.GetList(opts, out more).Tables[0];
// for (int tc = 0; tc < t.Columns.Count; tc++) //DEBUGGING CODE
// str +=t.Columns[tc].ColumnName + " | "; //DEBUGGING CODE
gridContacts.DataSource =conTable;
// // SET FONT for Default row to True
// if(e.Row.Cells.FromKey(âShipToNumâ).Value == â** default **â)
// e.Row.Style.Font.Bold = true;
try{
//Disable all columns except first ("Selected")
for (int i=1; i < gridContacts.DisplayLayout.Bands[0].Columns.Count; i++) {
gridContacts.DisplayLayout.Bands[0].Columns[i].CellActivation = Activation.ActivateOnly;
//Disable all lontacts who don't have email so they cannot be selected
DisableContactsWithoutEmail(conTable.Rows.Count);
//Hide the 2 columns needed for behind teh scenes data access...
gridContacts.DisplayLayout.Bands[0].Columns["CustNum"].Hidden = true;
gridContacts.DisplayLayout.Bands[0].Columns["CustNumCustID"].Hidden = true;
} catch{}
//try{SearchOnCustContactsAdapterShowDialog(true);} catch{}
MessageBox.Show ("ERROR!!" + Environment.NewLine + excep.Message); }
private static void DisableContactsWithoutEmail(int _rowcount)
for (int i = 0; i < _rowcount; i++)
if (gridContacts.Rows[i].Cells["ShipToNum"].Value.ToString()== "** default **")
gridContacts.Rows[i].Appearance.ForeColor = System.Drawing.Color.Blue; // System.Windows.Media.Color.Blue; //.Bold = true;
//Disable all rows with "blank" email addresses...
if (gridContacts.Rows[i].Cells["EMailAddress"].Value.ToString().Length <=0)
gridContacts.Rows[i].Activation = Infragistics.Win.UltraWinGrid.Activation.Disabled;
private static void buttonCloseContactList_Click(object sender, System.EventArgs args)
private static void btnContinue_Click(object sender, System.EventArgs args)
try
if (gridHeader.DataSource != null) {
gridHeader.ReadOnly = false;
} else { return; }
ProcessSelectedInvoices("MAIL");
if (gridHeader.DataSource != null) { gridHeader.ReadOnly = true; }
catch (Exception exception)
MessageBox.Show("Exception encountered while attempting to e-mail invoices! " + Environment.NewLine + exception.Message);
if (gridHeader.DataSource != null) { gridHeader.ReadOnly = true;}
private static void buttonEmail_Click(object sender, System.EventArgs args)
groupContactSelector.Width = 536;
groupContactSelector.Height = 214;
groupContactSelector.Visible = true;
((System.Windows.Forms.Control)groupContactSelector).BringToFront();
//((System.Windows.Forms.Control)groupPrintOptions).SendToBack();
((System.Windows.Forms.Control)gridHeader).SendToBack();
private static void buttonPrint_Click(object sender, System.EventArgs args)
ProcessSelectedInvoices("PRINT");
private static void ProcessSelectedInvoices(string _action)
try
string recipients = "";
if (gridHeader.DataSource == null)
return;
if (session.UserEmail == null)
MessageBox.Show("Please update your email address using Epicor User Maintenance and then login to Epicor before continuing.");
return;
if (session.UserEmail.Trim() =="")
return;
DataRow[] invoiceList = ((DataTable)gridHeader.DataSource).Select("Calculated_Selected=true");
if (invoiceList.Length == 0) {
MessageBox.Show("No invoices have been selected.");
return;
DataRow[] recipientList = ((DataTable)gridContacts.DataSource).Select("Selected=true");
//MessageBox.Show("Copy Self? " + epiCheckEmailCopySelf.Checked.ToString() + Environment.NewLine + "Action: " + _action + Environment.NewLine + "Recipients " + recipientList.Length.ToString());
if (recipientList.Length <= 0 && (!epiCheckEmailCopySelf.Checked) && _action == "MAIL") {
MessageBox.Show("No recipients have been selected.");
return;
else
if (recipientList.Length>0)
foreach (DataRow contact in recipientList)
recipients+=contact["EmailAddress"].ToString() + ", ";
if (recipients.Length > 2)
recipients = recipients.Substring(0, recipients.Length - 2);
MessageBox.Show ("RecipientList Compiled - " + recipients); //DEBUGING CODE
action = _action;
Hashtable custInvoices = FindInvoices(invoiceList);
if (custInvoices == null) {
return;
//MessageBox.Show("Found Invoices"); //DEBUGGING CODE
Worker w = new Worker(custInvoices, invoiceList, recipients, epiCheckEmailCopySelf.Checked); // ( _action == "PRINT"?recipientList:null) );
//MessageBox.Show("Worker Instantiated"); //DEBUGGING CODE
thread = new Thread(new ThreadStart(w.Update));
thread.Start();
static Hashtable FindInvoices(DataRow[] invoiceList)
Hashtable custInvoices = new Hashtable();
// Find invoices for each customer
foreach (DataRow row in invoiceList) {
// string custID = (string)row[âCustomer.CustIDâ];
string custID = (string)row[âCustomer_CustIDâ];
List<DataRow> invoices = custInvoices.Contains(custID) ? (List<DataRow>)custInvoices[custID] : new List<DataRow>();
invoices.Add(row);
custInvoices[custID] = invoices;
// Find contacts for each customer
foreach (string custID in custInvoices.Keys) {
DataRow invoice = ((List<DataRow>)custInvoices[custID])[0];
if (action != "MAIL") {
custContacts[custID] = new Contact((int)invoice["InvcHead_InvoiceNum"], custID, "", "");
continue;
opts.NamedSearch.WhereClauses["CustCnt"] = "CustNum="+invoice["InvcHead_CustNum"]; //["Customer.CustNum"];
bool more;
// return null;
// return null;
custContacts[custID] = new Contact((int)invoice[âInvcHead_InvoiceNumâ], custID, custID + â_â + session.UserName, session.UserEmail);
// Display confirmation message
string msg = "";
foreach (string custID in custContacts.Keys) {
Contact contact = (Contact)custContacts[custID];
if (msg != "") msg += "\n";
msg += custID+" "+contact.Name+" "+contact.EmailAddress+":\n ";
foreach (DataRow invoice in (List<DataRow>)custInvoices[custID]) {
msg += invoice["InvcHead_InvoiceNum"] + ",";
msg = msg.Substring(0,msg.Length-1);
string a = (action == "MAIL") ? "Email" : ((action == "PRINT") ? "Print" : "Create PDF");
DialogResult res = EpiMessageBox.Show(msg, a+" invoices?", MessageBoxButtons.YesNo);
return (res == DialogResult.Yes) ? custInvoices : null;
private static string AddFilter(string filter, string expr, object v, bool quoted)
if (v == null || Convert.IsDBNull(v) || v.ToString() == "")
return filter;
if (filter != "") filter += " AND ";
return filter + expr + (quoted ? "'" : "") + v + (quoted ? "'" : "");
// Sets status text and cursor to busy
private static void SetStatusText(string msg)
try {oTrans.PushDisposableStatusText(msg, !msg.StartsWith("Ready"));} catch {}
private static bool SendEmail(string toAddr, bool CCSelf, string subject, string body, List<string> files)
bool ret = true;
CompanyAdapter companyAdapter = new CompanyAdapter(oTrans);
companyAdapter.BOConnect();
companyAdapter.GetByID(session.CompanyID);
string fromAddr = session.UserEmail; //"ar@CAToronto.ca";
//string fromAddr = (string) companyAdapter.CompanyData.Company.Rows[0]["EmailFromAddr"];
string smtpServer = (string) companyAdapter.CompanyData.Company.Rows[0]["SMTPServer"];
int smtpPort = (int) companyAdapter.CompanyData.Company.Rows[0]["SMTPPort"];
companyAdapter.Dispose();
if (fromAddr == "" || smtpServer == "" || smtpPort == 0) {
MessageBox.Show("1 or more values are not set in Company Configuration:\nGlobal Alert Email From, SMTP server or SMTP port");
return false;
//MessageBox.Show("from="+fromAddr+" smtp="+smtpServer+" port="+smtpPort); //debugging code
// Send the notification
SmtpClient client = new SmtpClient(smtpServer, smtpPort);
//client.Credentials = new NetworkCredential("account-name", "password");
//MailAddress from = new MailAddress(fromAddr, session.UserName + "_CATorontoAR", System.Text.Encoding.UTF8);
//MessageBox.Show (toAddr); //Debugging code
//MailAddress to = new MailAddress(toAddr);
//MailAddress to = new MailAddress("Shanna@CAToronto.ca"); //("Bdalal@CAToronto.ca");
//MailMessage message = new MailMessage(from, to);
MailMessage message = new MailMessage();
//message.Sender = new System.Net.Mail.MailAddress(fromAddr, session.UserName + "_CATorontoAR", System.Text.Encoding.UTF8);
message.From= new System.Net.Mail.MailAddress(fromAddr, session.UserName + "_CATorontoAR", System.Text.Encoding.UTF8);
if (toAddr.Length>0) message.To.Add(toAddr);
if (CCSelf) message.CC.Add(fromAddr);
message.Subject = subject;
message.Body = body;
foreach (string file in files) {
Attachment attach = new Attachment(file, System.Net.Mime.MediaTypeNames.Application.Pdf);
message.Attachments.Add(attach);
try {
client.Send(message);
} catch (Exception e) {
MessageBox.Show("SendEmail error: "+e.Message);
ret = false;
message.Dispose();
return ret;
static bool InitPrintData()
if (action == "PRINT" && dialog == null) {
dialog = new PrintDialog();
if (dialog.ShowDialog() != DialogResult.OK) {
dialog = null;
return false;
if (serverDir != null && crystalRptFile != null)
return true;
SetStatusText("Finding server directories.");
// Get server and client data directories
SysAgentAdapter agentAdapter = new SysAgentAdapter(oTrans);
agentAdapter.BOConnect();
string agentID;
agentAdapter.GetDefaultTaskAgentID(out agentID);
agentAdapter.GetByID(agentID);
dataDir = (string)agentAdapter.SysAgentData.SysAgent.Rows[0]["ClientFileRootDir"];
serverDir = (string)agentAdapter.SysAgentData.SysAgent.Rows[0]["ClientProgRootDir"];
agentAdapter.Dispose();
// Find default or 1st Crystal Report file
SetStatusText("Finding AR Inventory style.");
ReportAdapter reportAdapter = new ReportAdapter(oTrans);
reportAdapter.BOConnect();
reportAdapter.GetByID("ARForm");
string filter = "Company='"+session.CompanyID+"' AND ValidStyle=true";
DataRow[] companyList = reportAdapter.ReportData.ReportComp.Select(filter+" AND IsDefault=true");
if (companyList.Length == 0) {
companyList = reportAdapter.ReportData.ReportComp.Select(filter);
foreach (DataRow compRow in companyList) {
DataRow reportStyle = reportAdapter.ReportData.ReportStyle.Select(" StyleDescription LIKE '%PDF%'")[0]; // ("StyleNum="+compRow["StyleNum"])[0];
if (((string)reportStyle["PrintProgram"]).EndsWith(".rpt")) {
crystalRptFile = ((string)reportStyle["PrintProgram"]).Replace('/', '\\');;
break;
reportAdapter.Dispose();
if (crystalRptFile == null) {
MessageBox.Show("Could not find a Crystal Report style for the 'ARForm' report.");
//btnEmail.Enabled = btnPrint.Enabled = btnPDF.Enabled = false;
return false;
// Crystal DLLs
SetStatusText("Loading Crystal DLLs");
//string[] dir = Directory.GetFiles(@"C:\Program Files\Business Objects\Common", "CrystalDecisions.CrystalReports.Engine.dll", SearchOption.AllDirectories);
string[] dir = Directory.GetFiles(@"C:\Windows\assembly", "CrystalDecisions.CrystalReports.Engine.dll", SearchOption.AllDirectories);
if (dir.Length == 0) {
MessageBox.Show("Could not find Crystal Report DLLs");
return false;
else {
crystalEngine = Assembly.LoadFrom(dir[0]);
dir = Directory.GetFiles(@"C:\Windows\assembly", "CrystalDecisions.Shared.dll", SearchOption.AllDirectories);
//string shared = dir[0].Substring(0,dir[0].LastIndexOf(@"\\")) + "\\CrystalDecisions.Shared.dll";
//crystalShared = Assembly.LoadFrom(shared);
if (dir.Length > 0)
crystalShared = Assembly.LoadFrom(dir[0]);
//MessageBox.Show("All Good!!"); //DEBUGGING CODE
else
MessageBox.Show("Could not find Crystal Report shared DLL");
SetStatusText("Ready.");
return true;
private static void Process(Hashtable custInvoices, DataRow[] invoiceList, string recipientEmails, bool emailCopySelf)
if (!InitPrintData())
return;
// Save subject and body if changed
if (action == "MAIL")
{ /*Check if subject / body need to be changed /.. */ }
progressBar.Value = 0;
progressBar.Maximum = invoiceList.Length;
List<string> pdfFileList = new List<string>();
foreach (DataRow invoice in ((List<DataRow>)custInvoices[custID])) {
int invcNum = (int)invoice["InvcHead_InvoiceNum"];
string type = (string)invoice["InvcHead_InvoiceSuffix"];
if (type == "") type = "IN";
SetStatusText(((action == "MAIL" || action == "PDF") ? "Creating PDF for " : "Printing ")+invcNum);
progressBar.PerformStep();
if (action == "MAIL") {
//MessageBox.Show("Preparing to PDF Invoice: " + invcNum.ToString() + "."); //DEBUGGING CODE
pdfFileList.Add(invcPrinter.PrintPDF(invcNum, type));
//MessageBox.Show("Invoice: " + invcNum.ToString() + " form created."); //DEBUGGING CODE
else if (action == "PDF") {
invcPrinter.PrintPDF(invcNum, type);
else if (!invcPrinter.PrintPaper(invcNum)) {
goto exit;
//MessageBox.Show("Preparing Email"); //DEBUGGING CODE
//Contact contact = (Contact)custContacts[custID];
//MessageBox.Show ("DEBUG: " + Environment.NewLine + "RecipientList Compiled - " + recipientEmails); //DEBUGING CODE
SetStatusText("Sending "+pdfFileList.Count+" invoices to "+ recipientEmails) ; //contact.EmailAddress);
//if (!SendEmail(contact.EmailAddress, txtSubject.Text, txtBody.Text, pdfFileList))
//if (!SendEmail(contact.EmailAddress, "CAToronto AR Invoices (" + custID + ")" , "Good Day. " + Environment.NewLine + " Attached find invoice(s). If you notice any descrepancies, please contact the sender of this email. ", pdfFileList))
if (!SendEmail(recipientEmails, emailCopySelf, "CAToronto AR Invoices (" + custID + ")" , "Good Day. " + Environment.NewLine +
goto exit;
if (!KeepGeneratedFiles)//(!cbxKeepFiles.Checked)
foreach (string file in pdfFileList) {
File.Delete(file);
// Set Processed flag for each invoice
//MessageBox.Show("Preparing adapter UD110 for logging"); //DEBUGGING CODE
ud110adapter.ClearData();
string field = (action == "MAIL" || action == "PDF") ? "CheckBox01" : "CheckBox02";
try {
ud110adapter.GetByID("INVOICE_MAILER", "PROCESSED", invcNum.ToString(),"","");
if ((bool)ud110adapter.UD110Data.UD110.Rows[0][field])
continue;
} catch {
//MessageBox.Show("Logging to UD110"); //DEBUGGING CODE
DataRow row = ud110adapter.UD110Data.UD110.Rows[0];
row["Key2"] = "PROCESSED";
row["Key3"] = invcNum.ToString();
row["Number01"] = invcNum;
row[field] = true;
//MessageBox.Show("UD110 adapter updated"); //DEBUGGING CODE
DataRow gridRow = ((DataTable)gridHeader.DataSource).Select("InvcHead_InvoiceNum="+invcNum)[0];
//gridRow[(action == "MAIL" || action == "PDF") ? "Mailed" : "Printed"] = true; //BD Throws errors FIX THIS
exit:
string msg = "Ready. ";
if (action == âPDFâ || (action == âMAILâ && KeepGeneratedFiles)) //cbxKeepFiles.Checked))
msg += "Files created in "+@"C:\Temp" + Environment.GetEnvironmentVariable(âUSERNAMEâ);
SetStatusText(msg);
class Contact {
public int InvcNum;
public string CustID, Name, EmailAddress;
public Contact(int invcNum, string custID, string name, string emailAddress)
this.InvcNum = invcNum; this.CustID = custID; this.Name = name; this.EmailAddress = emailAddress;
} //END OF CONTACT class
class InvcPrinter : Erp.UI.Rpt.ARInvForm.Transaction {
public InvcPrinter(object sender) : base(sender) {
// Returns create PDF filename
string GenerateXML(int invcNum)
SetStatusText("Generating data for "+invcNum);
Invoice = invcNum.ToString();
setInvoice();
RunDirect("GenerateDirect");
string[] files = Directory.GetFiles(dataDir + @"\Reports\"+ session.UserID, "AR Invoice Form*.xml");
string xmlFile = files[files.Length-1];
SetStatusText("XML file: "+xmlFile);
crystalRpt = crystalEngine.CreateInstance("CrystalDecisions.CrystalReports.Engine.ReportDocument");
Type ReportDoc = crystalEngine.GetType("CrystalDecisions.CrystalReports.Engine.ReportDocument");
//MessageBox.Show("instantiated CR"); //DEBUGGING CODE
// OpenReportMethod.OpenReportByDefault
Type OpenReportMethod = crystalShared.GetType("CrystalDecisions.Shared.OpenReportMethod");
FieldInfo openReportByDefaultInfo = OpenReportMethod.GetField("OpenReportByDefault");
object OPEN_BY_DEFAULT = openReportByDefaultInfo.GetValue(null);
//MessageBox.Show("SET OPEN BY DEFAULT"); //DEBUGGING CODE
// crystalRpt.Load()
//MessageBox.Show("preparing to 'load' CR object " + serverDir+@"\"+crystalRptFile); //DEBUGGING CODE
MethodInfo load = ReportDoc.GetMethod("Load", new Type[] { typeof(string) }); //, OpenReportMethod });
load.Invoke(crystalRpt, new object[] { serverDir+@"\"+crystalRptFile}); //, OPEN_BY_DEFAULT });
//MessageBox.Show("'Loaded' CR " + serverDir+@"\"+crystalRptFile); //DEBUGGING CODE
// crystalRpt.SetDataSource()
DataSet ds = new DataSet();
ds.ReadXml(xmlFile);
MethodInfo setDataSource = ReportDoc.GetMethod("SetDataSource", new Type[]{typeof(DataSet)});
setDataSource.Invoke(crystalRpt, new object[] { ds });
// crystalRpt.ReportDefinition
Type ReportDefinition = crystalEngine.GetType("CrystalDecisions.CrystalReports.Engine.ReportDefinition");
PropertyInfo reportDefinitionInfo = ReportDoc.GetProperty("ReportDefinition");
object reportDefinition = reportDefinitionInfo.GetValue(crystalRpt, null);
//MessageBox.Show("instantiated RD"); //DEBUGGING CODE
// crystalRpt.ReportDefinition.ReportObjects
Type ReportObjects = crystalEngine.GetType("CrystalDecisions.CrystalReports.Engine.ReportObjects");
PropertyInfo reportObjectsInfo = ReportDefinition.GetProperty("ReportObjects");
object reportObjects = reportObjectsInfo.GetValue(reportDefinition, null);
//MessageBox.Show("instantiated RD Objects"); //DEBUGGING CODE
Type SubreportObject = crystalEngine.GetType("CrystalDecisions.CrystalReports.Engine.SubreportObject");
PropertyInfo subreportNameInfo = SubreportObject.GetProperty("SubreportName");
//MessageBox.Show("instantiated SubReport infrastructure"); //DEBUGGING CODE
// Set datasource of each subreport
foreach (object reportObj in ((System.Collections.ICollection)reportObjects)) {
if (reportObj.GetType() != SubreportObject)
continue;
//MessageBox.Show("Set datasource for subreport(s)"); //DEBUGGING CODE
string name = (string)subreportNameInfo.GetValue(reportObj, null);
MethodInfo openSubreport = ReportDoc.GetMethod("OpenSubreport", new Type[] { typeof(string) });
object subRpt = openSubreport.Invoke(crystalRpt, new object[] { name });
setDataSource.Invoke(subRpt, new object[] { ds });
//MessageBox.Show("xml file prepared"); //DEBUGGING CODE
return xmlFile;
public string PrintPDF(int invcNum, string type) {
string xmlFile = GenerateXML(invcNum);
string pdfDirectory = @"C:\Temp\" + Environment.GetEnvironmentVariable("USERNAME");
string pdfFile = pdfDirectory + "\\" + type + " " + invcNum + ".pdf";
try{Directory.CreateDirectory(pdfDirectory);}
catch (Exception exception) {MessageBox.Show("Exception creating Directory! " + exception.Message);}
// ExportDestinationType.DiskFile
Type ExportDestinationType = crystalShared.GetType("CrystalDecisions.Shared.ExportDestinationType");
FieldInfo diskFileInfo = ExportDestinationType.GetField("DiskFile");
object DISKFILE = diskFileInfo.GetValue(null);
//MessageBox.Show("set destination .. diskfile " ); //DEBUGGING CODE
// crystalRpt.ExportOptions
PropertyInfo exportOptionsInfo = ReportDoc.GetProperty("ExportOptions");
object exportOptions = exportOptionsInfo.GetValue(crystalRpt, null);
Type ExportOptions = crystalShared.GetType("CrystalDecisions.Shared.ExportOptions");
//MessageBox.Show("set and instantiated Export Options" ); //DEBUGGING CODE
// crystalRpt.ExportOptions.ExportDestinationType
PropertyInfo exportDestinationTypeInfo = ExportOptions.GetProperty("ExportDestinationType");
exportDestinationTypeInfo.SetValue(exportOptions, DISKFILE, null);
//MessageBox.Show("Set export destination type" ); //DEBUGGING CODE
// ExportFormatType.PortableDocFormat
Type ExportFormatType = crystalShared.GetType("CrystalDecisions.Shared.ExportFormatType");
FieldInfo portableDocFormatInfo = ExportFormatType.GetField("PortableDocFormat");
object PORTABLE_DOC_FORMAT = portableDocFormatInfo.GetValue(null);
//MessageBox.Show("Set CRW portable Doc Format" ); //DEBUGGING CODE
// crystalRpt.ExportOptions.ExportFormatType
PropertyInfo exportFormatTypeInfo = ExportOptions.GetProperty("ExportFormatType");
exportFormatTypeInfo.SetValue(exportOptions, PORTABLE_DOC_FORMAT, null);
// DiskFileDestinationOptions.DiskFileName
Type DiskFileDestOptions = crystalShared.GetType("CrystalDecisions.Shared.DiskFileDestinationOptions");
PropertyInfo diskFileNameInfo = DiskFileDestOptions.GetProperty("DiskFileName");
object diskOptions = crystalShared.CreateInstance("CrystalDecisions.Shared.DiskFileDestinationOptions");
diskFileNameInfo.SetValue(diskOptions, pdfFile, null);
//MessageBox.Show("Set Diskfile Destination options" ); //DEBUGGING CODE
// crystalRpt.ExportOptions.DestinationOptions
PropertyInfo destinationOptionsInfo = ExportOptions.GetProperty("DestinationOptions");
destinationOptionsInfo.SetValue(exportOptions, diskOptions, null);
// crystalRpt.ExportOptions.FormatOptions
PropertyInfo formatOptionsInfo = ExportOptions.GetProperty("FormatOptions");
object formatOptions = crystalShared.CreateInstance("CrystalDecisions.Shared.PdfRtfWordFormatOptions");
formatOptionsInfo.SetValue(exportOptions, formatOptions, null);
// crystalRpt.Export()
MethodInfo export = ReportDoc.GetMethod("Export", new Type[]{});
export.Invoke(crystalRpt, null);
//MessageBox.Show("Invoking Export!" ); //DEBUGGING CODE
// crystalRpt.Close()
MethodInfo close = ReportDoc.GetMethod("Close", new Type[] {});
close.Invoke(crystalRpt, null);
File.Delete(xmlFile);
return pdfFile;
public bool PrintPaper(int invcNum) {
SetStatusText("Printing");
// crystalRpt.PrintOptions
PropertyInfo printOptionsInfo = ReportDoc.GetProperty("PrintOptions");
object printOptions = printOptionsInfo.GetValue(crystalRpt, null);
Type PrintOptions = crystalEngine.GetType("CrystalDecisions.CrystalReports.Engine.PrintOptions");
// crystalRpt.PrintOptions.PrinterName
PropertyInfo printerNameInfo = PrintOptions.GetProperty("PrinterName");
printerNameInfo.SetValue(printOptions, dialog.PrinterSettings.PrinterName, null);
//crystalRpt.PrintToPrinter(1, false, 0, 0);
MethodInfo printToPrinter = ReportDoc.GetMethod("PrintToPrinter", new Type[] { typeof(int), typeof(bool), typeof(int), typeof(int) });
printToPrinter.Invoke(crystalRpt, new object[] { 1, false, 0, 0 });
return true;
} // END OF INVCPRINTER class
class Worker {
DataRow[] invoiceList;
string recipientsEmails;
bool emailSelf;
public Worker(Hashtable custInvoices, DataRow[] invoiceList)
this.custInvoices = custInvoices;
this.invoiceList = invoiceList;
this.recipientsEmails = null;
this.emailSelf = false;
public Worker(Hashtable custInvoices, DataRow[] invoiceList, string recipients)
this.recipientsEmails = recipients;
public Worker(Hashtable custInvoices, DataRow[] invoiceList, string recipients, bool sendEmailToSelf)
this.emailSelf = sendEmailToSelf;
public void Update()
try {
Process(custInvoices, invoiceList, recipientsEmails, emailSelf);
//btnEmail.Enabled = btnPrint.Enabled = btnPDF.Enabled = true;
if (!threadAborted && Thread.CurrentThread.ThreadState == System.Threading.ThreadState.Running) {
ExceptionBox.Show(e);
} //END OF WORKER class
Greg,
I am using this code to hide a tree panel but it is saying Iâm missing an assembly reference. Do you know which one is needed?
@skearney Here are the Infragistics usings I have always added.
using Infragistics.Shared;
using Infragistics.Win;
using Infragistics.Win.UltraWinToolbars;
using Infragistics.Win.UltraWinDock;
