Hi Paul,
Yes - once again, it's a business process issue and not necessarily a Vantage issue!
On the one hand, our Machine Shop wants the flexibility to scrap at their Job Operation. On the other hand, our Quality group would like to be able to monitor that process with a NCM/Inspection/DMR process - as per your proposal. (You can probably tell who won that argument - which is why I have to write the Labor Scrap Report!)
I guess it comes down to whatever your business needs are - certainly an inspection process will provide a lot more tracking, but it'll also require a bit more effort.
Good luck!
Laraine
Good luck!
Laraine
--- In vantage@yahoogroups.com, Paul Smith <psmith@...> wrote:
> Laraine
> Thank you for your input. It seems to me that using the labor entry screen to scrap material/assemblies is not the best method. We, as a company, are pushing very hard to learn and utilize Vantage the way it was designed. I believe using the non-conformance/inspection processing/DMR processing is the best way to scrap an assembly off the job, is that a fair statement? Again thank you.
> The short answer is nothing happens when you report scrap in labor entry. Basically, it's material variance just like any other material variance you might have on the job. For better or worse, Epicor leaves this up to you what you want to do with the information.
> --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, "laraines422" <laraines422@> wrote:
> > Hi Paul,
> > We're on 8, so I can't tell if this will help or not.
> > Our Machine Shop wants to be able to relate the scrap transactions as shown on the Inventory WIP Report (MFG-VAR) to specific labor transactions. Fortunately, they are a separate plant so it's relatively easy to isolate their transactions.
> > I finally got an RDD copy of this report linked to Labor Detail - I've been working on it off and on - it's not as straight-forward as I had hoped, as least as far as identifying the specific Job Operation where the scrap event occured.
> > Anyway - you might check with your Accounting group and see how they handle the postings to your variance accounts.
> > Good luck!
> > Laraine
> > --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, Paul Smith <psmith@> wrote:
> > > Using vantage 6 what happens when you scrap within labor entry? I see if I do a non-conf it goes to the QC module. But if I scrap an item I see no transactions. Where is the cost and the part going? Thanks in advance.
> > > Paul Smith
> > > Inventory Management
> > > 233 Ballston Ave
> > > Saratoga Springs NY, 12866
> > > 518-245-4358
> > > ________________________________
> > > The information contained in this message is intended solely for the individual it is specifically and originally addressed. This message and its contents may contain confidential or privileged information. If you are not the intended recipient, you are hereby notified that any disclosure or distribution, or taking any action in reliance on the content of this information is strictly prohibited. If you received this message in error, please delete it from any computer and notify the sender. If you suspect that this message may have been altered, please notify the sender.
