The way we do this is similar we create a resource group for each operation and we assign resources (people) to the resource group based on how many people work that operation. The resources are given calendars based on the entire workday (avg 96 hrs) based on 2 shifts and overtime. this way it is scheduled as you want it to be. if there can be more than one person working on different jobs at the same time you can set that up in the resource group also. in the job you can also say how many scheduling blocks to assign.
--- In vantage@yahoogroups.com, "Scotty K." <scottyk537@...> wrote:
> The workaround is to create a resource with a schedule spanning three
> shifts. This one resource would represent three employees.
> It works for us, we just have to remember to manually adjust these
> resources when our head counts change.
> Scott
> On Thu, Aug 15, 2013 at 10:52 AM, Rob Bucek <rbucek@...> wrote:
> > You can't do that. The scheduling engine doesn't have the ability to
> > schedule across multiple calendars on a single operation. It is one of the
> > biggest design flaws in Epicor Scheduling.
> > Rob Bucek
> > Production Control Manager
> > PH: (715) 284-5376 ext 311
> > Mobile: (715)896-4832
> > FAX: (715)284-4084
> > [cid:1.234354861@...]<http://www.dsmfg.com/>
> > (Click the logo to view our site)<http://www.dsmfg.com/>
> > From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf
> > Of khambleton500@...
> > Sent: Thursday, August 15, 2013 10:15 AM
> > Subject: [Vantage] Scheduling in 9.05.702A
> > We are in the process of setting up the scheduling module on E9. We have
> > run into a snag. We want to be able to schedule across 3 shifts. What we
> > are seeing is the schedule picks the first work force resource and
> > schedules the operation to run for as many hours as that person is
> > available. For example the operation should take 18 hours, my 1st shift
> > work force is available for 8 hours, second shift available for 10 hours.
> > So you would assume that the workforce resource would schedule 18 hours.
> > But it doesn't, it schedules the workforce resource over a 3 day period, 8
> > hours day one, 8 day two and 2 hours day 3. We don't understand why it
> > doesn't schedule 8 hours on 1st shift and then pick the 2nd shift workforce
> > to continue for another 10 hours. Is there anyone out there who is
> > scheduling over multiple shifts? Could you share how you have your
> > workforce setup?
> > Thanks,
> > Kathy
> > Kathy Hambleton
> > Electron Energy Corporation
> > 717-459-1056
