Carey,
It is a crime Epicor doesn't give you or your company benefit for your willingness to share your superior knowledge of the topic.
You just explained the use of capabilties in a few paragraphs MUCH more effectively than any Epicor employee has managed to do (at a cost of days of consulting fees).
Thank you.
I still contend that for the resulting quality of schedules (the worst I've experienced in 25 years in fact), the Epicor modeling paradigm is grossly & needlessly complex.
Capabilities (based upon your excellent explanation) certainly do provide a means for more accurately modeling actual scheduled processes.
I still contend however that doing so increases the long term non-value-added maintenance cost of maintaining a model that, in every other system I've had experience with, is achieved just as well (or better) with far less complexity.
It truly seems to be a case where programmers (with no real world manufacturing experience) went wild trying to build a better mouse trap that simply was not needed.
Thank you though (and good luck getting over that sinus infection).
Rob Brown
Carey S <rotary1@...> wrote:
You will undoubtedly hear many opinions about this. The confusion is very justified.
There are fundamental principles and considerations here, and as expressed in a post by Robert, you will notice that there is no readily-available resource at Epicor that will be abe to quickly give you much advise here.
There are a couple of points to consider beyond what is already mentioned.
First, at Perspectives, you will hear course instructors mention to you that you SHOULD NOT schedule people as resources. This is a huge burden if you have any labor turnover, as this precludes you from using named labor, and instead "expert 1", "expert 2", etc.
I struggled for a long time with this consideration, and then I decided to explore "floating" human labor. This opened up a whole new world of understanding.
Robert mentions Capability in another thread, and although mentioned throughout the help files, there is nothing useful there or in any of the Epicor documentation that I have seen.
In order to use capabilities, you would need APS. I have spoken to many people who have purchased this license based on conversations they have had with me.
So, while I do not profess to be a manufacturing expert, Epicor has seen fit to use me as a reference.
Effectively, you can use capability to get around the one-to-one relationship between resources and resource groups.
Here is the basic example from Epicor:
Imagine you have 2 resources:
1) basic machining (3 axis requirement)
2) advanced machining (4 axis requirement)
I could set up 2 capabilities (effectively skill sets)
A) simple machining
b) Complex machining
I could set up the members of this capability as follows :
Cap A = 3 axis machine, AND 4 axis machine
Cap B = 4 axis machine (ONLY)
And this is a simple illustration of the one-to-many expansion.
But this is only basic. Suffice it to say, you now set your scheduling requirements based on capability, not resource or group.
You can assign schedules, vacations (and maint) by the group, or the specific resource...is cool now because I can schedule the exceptions for employee vacations.
But going a step further, I can then set load priorities on each resource with the capability. Therefore, in the labor capability of "Quality Inspection", I could choose to load the resources in the order of "Person 2, Person 3, Person 1.
This leaves my most cross-trained person available should he be needed elsewhere, but still available for any of the required operations.
Going a step further, I can qualify the operation standards based on he specific resource who actually does the labor.
For example, referring to the same labor capability, I would set up the operation and the standard for Person 2 to "1". This tells the system that with an op standard of x piece per hour, the percentage of the standard expected to be needed by Person 2 is 100-percent. I could then define the capability spec for person 3 to be ".8" which would tell the system to expect 80-percent the output of the standard (this resource works more slowly, or whatever....
Anyway, you can see that APS and capabilities are really quite powerful.
I have talked to so many people who would have been better off to start with APS had they known the true benefits...unfortunately not effectively explained by Epicor to the disservice of themselves as well as their customers.
The addition of APS gives you not only the listed benefit, but removes the 2 exception limit on operations of standard Vantange/Vista production.
Note that this does not answer questions about whether this is something you should do in your particular situation, but there is validity in your question.
I do not make it a habit of publicizing all of this information as I find it unfair to provide Epicor the benefit when corporately, they have not given my company other considerations ( I do not get free documentation), but will be happy to answer any direct questions anyone might have.
Meanwhile, it is midnight here and I am suffering with a Sinus infection, so undoubtedly, my hands have missed typiing something my head might not realize, so I apologize in advance if that is the case.
Carey
To: vantage@yahoogroups.comFrom: nimish_bhatia1@...: Fri, 21 Dec 2007 05:20:32 +0000Subject: [Vantage] Scheduling employees as resources
We are a machining and fabrication shop doing mostly made to order (orengineered to order) parts with approx 250 employees. We currentlyfeel that we have too many employees for the amount of work beingdone. One of the main reasons we want vantage is to see whichemployees are working on what jobs so we can understand ourproductivity better.In order to see the productivity, I would assume we need to create allemployees as individual resources and choose the appropriate resourcewhile scheduling a job. However, since I'm new to vantage, I'm notsure of the advantages and disadvantages of using this system. Itobviously adds more detail during the scheduling phase, but I'm notsure if there are other pros and cons that I can't think of. In fact,I'm not sure if this is too much detail for scheduling that we willnot be able to maintain in the long run.Can someone help me understand whether to go this route or not? Ifnot, what other ways are there to better see which employee is
workingon which job so we can understand the productivity of employees on theshop floor.Thanks.
__________________________________________________________
Share life as it happens with the new Windows Live.
http://www.windowslive.com/share.html?ocid=TXT_TAGHM_Wave2_sharelife_122007
Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now.
Thank you.
Rob Brown
A) simple machining
Carey
