I am working on the most appropriate way to set up my operations to do what I need. We have tried a number of different things, But I am still fuzzy on how a scheduling block will work for us or If i need to think about this differently. Basically, I really need to split 1 operation to 3 employees, in the same assembly station.
Scenario:
we build police cars - this is our finished good. Each job builds 1 vehicle. In this scenario, we never have 1 job building more that 1 of anything as it’s finished good.
To build it, it requires about 50 man hours of labor. It takes up 1 bay space during those hours.
I am currently planning on having an operation called “Police car assembly”. it would always be for 1 unit, that takes 50 hours to build. It would be assigned the Resource groups of “assembly bays” and “Assembly employees”.
“assembly bay” has resources of bay 1, 2, 3, 4. “assembly employees” has employees 1,2,3,4,5,6,7,8,10,11,12. So technically, we should be able to run 4 bays with 3 people each.
IF I understand scheduling blocks right, I feel it will assign the appropriate employees if I put the block at 3, BUT I feel it will also try to split into multiple bays, even though it is a single unit. am i wrong to think this? since it is a single finished good, will it just split the employees? How the heck does it know the difference between the employee and the bay?
Anyone have any insite on this or experience in a similar scenario? We have worked on using multiple operations on the same job, but the schedule is technically “moving” the vehicle from 1 bay to another, and it doesn’t seem to schedule anymore the 1 employee to each op.
Epicors example is always about an airplane manufacturer. it is almost the same thing. assemble the airplane with multiple people, but in the same space. How would you set up your Ops and group to accomplish this?
Thanks in advance!
