Schedule A New Stock Job Via C# Directive
Hi eveyone,
I did some preliminary digging before creating this post and didn’t see anything of specific help so hopefully I have not missed something. I am looking for some help or potentially a headstart on some C# Code for a Post Processing Method Directive to completely Schedule an Unscheduled stock workorder job entirely through C#. I already ran a trace log on the scheduling process from Job Entry and I am starting there-- but I am unfortunately in some extreme crunch time on figuring this out for my client and I was hoping there might be a snippet of code out there that could give me a head start.
I already have access to the obviously necessary data like Company/Plant/JobNum and the Date I am trying to (forward) Schedule the job to.
I assume I will have to use either the JobEntry service contract, JobScheduling service contract, or the SchedulingEngine contract-- so I have grabbed all of these references to start.
Any assistance on this topic is greatly appreciated-- Will update with any progress or other questions as I go.
Thank you,
Dylan
Easiest way would probably to run a trace through Quick Job Entry that will for sure cut down on the code needed to do it.
I would walk through that process quick see if you get the result you are looking for then run a trace if you do. The number of fields required is heavily reduced.
I use this in a dashboard.
try
							var schedDS = new Erp.Tablesets.ScheduleEngineTableset() ;
							var sp = schedDS.ScheduleEngine.NewRow() ;
							sp["Company"]	 	   = callContextClient.CurrentCompany ;
							sp["JobNum"]		     = jobNum ;
							sp["AssemblySeq"] 	 = 0 ;
							sp["OprSeq"]      	 = 0 ;
							sp["OpDtlSeq"]    	 = 0 ;
							sp["StartDate"]   	 = startDate ;
							sp["StartTime"]   	 = 0 ;
							sp["EndDate"]     	 = dueDate ;
							sp["EndTime"]     	 = 0 ;
							sp["WhatIf"] 		    = false ;
							sp["Finite"] 		    = false ;
							sp["SchedTypeCode"]  	  = "jj" ;
							sp["ScheduleDirection"]  = "End" ; //"Start" ;
							sp["SetupComplete"]  	  = false ;
							sp["ProductionComplete"] = false ;
							sp["OverrideMtlCon"]	   = true ;
							sp["OverRideHistDateSetting"] = 2 ;
							sp["RecalcExpProdYld"] 	     = false ;
							sp["UseSchedulingMultiJob"]   = false ;
							sp["SchedulingMultiJobIgnoreLocks"]  = false ;
							sp["SchedulingMultiJobMinimizeWIP"]  = false ;
							sp["SchedulingMultiJobMoveJobsAcrossPlants"] = false ;
							sp["SysRowID"] 		 = Guid.NewGuid() ;
							sp["RowMod"]        = "A" ;
							schedDS.ScheduleEngine.Add( sp );
							Ice.Diagnostics.Log.WriteEntry("In MoveJobitem " + jobNum.ToString() + " pn " + dueDate.ToString());
							boSched.MoveJobItem( schedDS, out finished, out Msg  ) ;
							ttr.Calculated_Status = "Scheduled - " + Msg ;
						} catch (Exception ex) {
							ttr.Calculated_Status = string.Format("Error: {0} Scheduling Job: {1}", ex.Message, jobNum) ;
Thank you Greg very much, this will help me greatly. I will get cracking.
Greg, if you don’t mind me asking, how did you define / declare the variable “ttr” in your example?
ttr is just the dashboard results to send back a status. You can just do a messagebox
Ah! Got it! Thank you so much man. You are a lifesaver. I was halfway there when I got your response earlier and it is taking me over the finish line my friend.
Marked Greg’s helpful response as solution to my Original Post.
Basic summary of how this is done for future help seekers:
  • using Ice.Assemblies;
    using Erp.Contracts;
  • ref ScheduleEngine assembly
  • create new var for ServiceRenderer.GetService<Erp.Contracts.ScheduleEngineSvcContract>(Db)
  • create new TableSet for Erp.Tablesets.ScheduleEngineTableset
  • create new row with ScheduleEngine.NewRow()
  • set all columns in the new row as follows sp[“Company”] = jh.Company;
  • add row to ScheduleEngine tableset like: schTs.ScheduleEngine.Add(sp);
  • call “MoveJobItem” method on the ScheduleEngine BO Contract like: sch.MoveJobItem( schTs, out b, out msg );
Once I have my code more finalized I will post what I can of it here.
