Saving customizations that won't compile
Hopefully I’m missing something, but I got frustrated again today when I accidentally saved a customization that failed compilation. As I understand it, there’s no way to recover this revision.
And if that’s the case, why am I allowed to save it? It shouldn’t be an option.
If you open it in developer mode and select the customization, you can go in and comment out the error. Save and reopen, the UI customizations should then be back.
Disregard - I thought it was reverting to a base form when it opened with the error. So it turns out, I WAS MISSING SOMETHING. Surprise!
You could also have access to it via Customization maintenance
Select Action / Custom data then Custom Code Tab,
