Save not working
You're on the right track. Some adapters (the ever changing with each release for PO entry is a great example) resist forced otrans.updates().
You need to (trial end error because of the crappy editor) try all kinds of event triggers (after_method, epinotifies, etc.,) to find out which is the last - then you can SOMETIMES force the save.
Rob
--- On Wed, 1/21/09, Michael McWilliams <mmcwilliams22@...> wrote:
Subject: [Vantage] Re: Save not working
Date: Wednesday, January 21, 2009, 11:37 AM
I wonder if it is something with the adapter in the UDEntry because
this works. I send the keys & have a hot key for save. If I replace
save with oTrans.Update( ) it does not work again. I some really
complex & lengthy customizations in other screens & they seem to
work fine with multiple updates while parsing the code.
Private Sub btnEpiCustom2_ Click(ByVal Sender As Object, ByVal Args
As System.EventArgs) Handles btnEpiCustom2. Click
'// ** Place Event Handling Code Here **
Dim UD01 As EpiDataView = Ctype(oTrans. EpiDataViews
("UD01"),EpiDataVie w)
txtEpiCustom6. Focus()
SendKeys.Send( "deburr")
SendKeys.Send( "{F10}")
--- In vantage@yahoogroups .com, "Michael McWilliams"
<mmcwilliams22@ ...> wrote:
> It is all set up correct.
> --- In vantage@yahoogroups .com, "Edward F. Fox, Jr." <efox@>
> wrote:
> > Did you go into menu structure maintenance and set the
> customization there?
> > If not it will clear it each time you leave the screen.
> > Edward F. Fox, Jr., CPA
> > Controller
> > Maxson Automatic Machinery Company
> > Phone 401-596-0162 Fax 401-596-1050
> > www.maxsonautomatic .com
> > _____
> > From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com]
On
> Behalf Of
> > Michael McWilliams
> > Sent: Wednesday, January 21, 2009 8:23 AM
> > To: vantage@yahoogroups .com
> > Subject: [Vantage] Save not working
> > I am wondering why the most simple of customizations will not
> work.
> > Every time you close out of the screen & go back in the
> shortchar01
> > has the old data.
Args
> > UD01.DataView( UD01.Row) ("ShortChar01" ) = "deburr"
> > otrans.update( )
I am wondering why the most simple of customizations will not work.
Every time you close out of the screen & go back in the shortchar01
has the old data.
Private Sub btnEpiCustom2_Click(ByVal Sender As Object, ByVal Args
As System.EventArgs) Handles btnEpiCustom2.Click
Dim UD01 As EpiDataView = Ctype(oTrans.EpiDataViews
("UD01"),EpiDataView)
UD01.DataView(UD01.Row)("ShortChar01") = "deburr"
otrans.update()
Did you go into menu structure maintenance and set the customization there?
Controller
Phone 401-596-0162 a Fax 401-596-1050
www.maxsonautomatic.com
_____
Michael McWilliams
has the old data.
otrans.update()
--- In vantage@yahoogroups.com, "Edward F. Fox, Jr." <efox@...>
> Controller
> _____
Behalf Of
> Michael McWilliams
work.
shortchar01
> has the old data.
> otrans.update()
save with oTrans.Update() it does not work again. I some really
txtEpiCustom6.Focus()
SendKeys.Send("deburr")
SendKeys.Send("{F10}")
--- In vantage@yahoogroups.com, "Michael McWilliams"
> --- In vantage@yahoogroups.com, "Edward F. Fox, Jr." <efox@>
> > Controller
> > _____
On
> Behalf Of
> > Michael McWilliams
> work.
> shortchar01
> > has the old data.
Args
> > otrans.update()
Have you tried:
UD01.dataView(UD01.Row).BeginEdit
UD01.dataView(UD01.Row).EndEdit
otrans.update()
Or:
UD01.Notify( New EpiNotifyArgs(oTrans, UD01.Row, UD01.Column))
otrans.update()
replace
> > > Controller
> > > _____
> On
> > Behalf Of
> > > Michael McWilliams
> > work.
> > shortchar01
> > > has the old data.
> Args
> > > otrans.update()
Method one works great, thanks. Still wonder why it behaves like
this on the UD form only though.
--- In vantage@yahoogroups.com, "bw2868bond" <bwalker@...> wrote:
> Have you tried:
Args
> otrans.update()
> Or:
Args
> otrans.update()
because
> replace
Args
> > > > Controller
> > > > _____
> > On
> > > Behalf Of
> > > > Michael McWilliams
not
> > > work.
> > > shortchar01
> > > > has the old data.
ByVal
> > Args
> > > > otrans.update()
